Posted May 16, 201016 yr I'm going to install two amps one is mono and the other is a 4 channel for my mids and highs. I already have the power, ground, and rem wire, but the only thing is how can i get two rca's if my headunit only has one connection?
May 16, 201016 yr More then likely your 4 channel is going to have a set on them that passes the signal through them. You can hook a set of RCAs to that and run to your mono block.
May 16, 201016 yr Or if it doesn't, you can just use some y-splitters near the amps to split the single RCA to both amplifiers.What HU do you have that only has a single pair of RCA outputs?
May 16, 201016 yr i think he means his sub out only has 1 rca and he wants to split it! but i could be wrong!
May 16, 201016 yr Author It's my cousins he has a walmart brand headunit. It is a Dual XR4110. How do the Y splitters work.
May 16, 201016 yr It's my cousins he has a walmart brand headunit. It is a Dual XR4110. How do the Y splitters work.not to make fun of you or anything but....LOL! a dual!?I remember be told in highschool by this shop that if was going to get a dual I might as well sell my car. Cause thats the only thing their good for.
May 17, 201016 yr It's my cousins he has a walmart brand headunit. It is a Dual XR4110. How do the Y splitters work.Pretty simple... One input goes in, and gets split into two.
