Posted May 19, 201016 yr Pre-ordering NOW OPEN... pre-order runs until July 4th or while supplies last.ETA is the end of July -- as always this is subject to delays and is not set in stone!COST : $315 shipped in the continental USA - Regular MAP Pricing is $375* Contact me for AK and HI orders* USA ONLY SALEIF YOU ORDER BY the end of May it will only be $300 each shipped in the continental 48 states!TO ORDER PAYPAL ME AT [email protected] with Subject "SAX-1200D Pre-Order" or talk to your favorite online or local Sundown Audio dealer.-----This is an all new board tooling developed just for Sundown Audio.RATINGS:1200 x 1 @ 1 ohm720 x 1 @ 2 ohms360 x 1 @ 4 ohms** -- Clamp testing coming soon... will post in this thread.These amps CAN be strapped.They are NOT 16v stable like the SAZ line and long term 0.5 ohm testing has not been completed.They have 4 awg power input terminals and 3x 40-Amp fuses.Effective real world power is expected to be significantly higher than the SAZ-1000D!Dimensions : 252(W) x 58(H) x 310(L)mm (9.92" x 2.28" x 12.2")-----* SAZ-1000D on left / SAX-1200D on right -- dual transformers and output inductors + new more powerful MOSFETs... all N channel outputs vs. N-P in the 1000D.* Side by side with 1000D for size reference.* Close up shot.
May 21, 201016 yr Just ordered can't wait to see what it will sound like with some sa-12s Edited May 21, 201016 yr by jyizzle1000
May 21, 201016 yr well let me know when real world 0.5ohm testing is done cause if its safe ill jump on it
May 25, 201016 yr Author Amps will be done in two days... around a month early (they are on the ball) -- so I now expect these late JUNE instead of July.Therefore pre-ordering will end sooner... around June 20th.
May 28, 201016 yr Amps will be done in two days... around a month early (they are on the ball) -- so I now expect these late JUNE instead of July.Therefore pre-ordering will end sooner... around June 20th.Cant wait for more testing on this amp. Im wondering how it will do at a 0.5 ohm? I know it would probably void the warranty but this thing looks like a small tank
June 4, 201016 yr Amps will be done in two days... around a month early (they are on the ball) -- so I now expect these late JUNE instead of July.Therefore pre-ordering will end sooner... around June 20th.Cant wait for more testing on this amp. Im wondering how it will do at a 0.5 ohm? I know it would probably void the warranty but this thing looks like a small tankIf your worried about how it will do at 0.5 ohm then get the SAZ-1500D and just run it at 1 ohm.
June 8, 201016 yr whats the different between the sax and sae1200???SAX is linkable and built by the same build house as the SAZSae is notBoth good lines!
June 30, 201016 yr is the SAX 1200d still expected at the end of this month (JUNE) like Jacob said?Jake will update this when they are ready to be shipped!
July 1, 201016 yr Author Pre-ordering closed. Depending on how fast the truck is I will have these somewhere between this Friday and next Wednesday.
July 2, 201016 yr i bet you do....... lol when we make out order we will have the entire amp line and will be doing side by side tests on all amps for everybody to see, eta 2-3weeks
July 3, 201016 yr i bet you do....... lol when we make out order we will have the entire amp line and will be doing side by side tests on all amps for everybody to see, eta 2-3weeksi want to hug you......... only with a good log and lots of amp porn tho.
