May 21, 201015 yr Can i put a a sundown 3500d on a single 15 fi bl?No since you have this question. The real question is why do you want to damage your sub, go get a BTL if you want to use that much power.
May 21, 201015 yr Author Can i put a a sundown 3500d on a single 15 fi bl?No since you have this question. The real question is why do you want to damage your sub, go get a BTL if you want to use that much power.Well whats the biggest amp i put on it?
May 21, 201015 yr Can i put a a sundown 3500d on a single 15 fi bl?No since you have this question. The real question is why do you want to damage your sub, go get a BTL if you want to use that much power.Well whats the biggest amp i put on it?have you even thought about looking at Fi's website to find out how much wattage the BL can handle?
May 21, 201015 yr Author Can i put a a sundown 3500d on a single 15 fi bl?No since you have this question. The real question is why do you want to damage your sub, go get a BTL if you want to use that much power.Well whats the biggest amp i put on it?have you even thought about looking at Fi's website to find out how much wattage the BL can handle?yeah its says 1000 but i have a us amps md2d with a kenetik hc1800 with upgraded alt and the amp is max out and the sub is asking for more
May 21, 201015 yr Can i put a a sundown 3500d on a single 15 fi bl?No since you have this question. The real question is why do you want to damage your sub, go get a BTL if you want to use that much power.Well whats the biggest amp i put on it?have you even thought about looking at Fi's website to find out how much wattage the BL can handle?yeah its says 1000 but i have a us amps md2d with a kenetik hc1800 with upgraded alt and the amp is max out and the sub is asking for morewhat do you mean maxed out? the gain is all the way up?how do you have the BL wired? to 1 ohm?
May 21, 201015 yr Author Can i put a a sundown 3500d on a single 15 fi bl?No since you have this question. The real question is why do you want to damage your sub, go get a BTL if you want to use that much power.Well whats the biggest amp i put on it?have you even thought about looking at Fi's website to find out how much wattage the BL can handle?yeah its says 1000 but i have a us amps md2d with a kenetik hc1800 with upgraded alt and the amp is max out and the sub is asking for morewhat do you mean maxed out? the gain is all the way up?how do you have the BL wired? to 1 ohm?yeah 1ohm and 0 guage wire and the gain is all the way up
May 21, 201015 yr If the amp was maxed out then you would be clipping your sub What makes you think it can take or physically handle more power? Your on the verge of having to get a recone real soon.Learn how to set your amp before worrying about how much power it can take. What size box is your speaker in?
May 21, 201015 yr yeah its says 1000 but i have a us amps md2d with a kenetik hc1800 with upgraded alt and the amp is max out and the sub is asking for moreExactly what do you mean by maxed out?
May 21, 201015 yr Author If the amp was maxed out then you would be clipping your sub What makes you think it can take or physically handle more power? Your on the verge of having to get a recone real soon.Learn how to set your amp before worrying about how much power it can take. What size box is your speaker in?the subs isn't clipping and its in a custom box tune for that sub
May 21, 201015 yr Well since you know everything then why are you asking us questions? Give us more information then what you are, telling me a box is customed tuned for the sub is nothing helpful at all.
May 21, 201015 yr Author Well since you know everything then why are you asking us questions? Give us more information then what you are, telling me a box is customed tuned for the sub is nothing helpful at all.To tell you the truth i dont know on the box side because i didnt build it but i got the specs off the website to fit it to the t. Cause i had superbass probox i busted it, it cracked crossed the top from one side to the other
May 21, 201015 yr Author How do you know the sub isn't clipping?cause it clipping is the subs cuts in and out right and it doesnt do that
May 21, 201015 yr HAHA. Do some research and go ahead and just email Fi for a recone.Why do people think the gain knob is a volume knob? If it was a volume knob, then it would be named a volume knob.
May 21, 201015 yr Better turn it down or you're going to break the sub...A gain isn't a volume knob chief.
May 21, 201015 yr I ran a pair of 15" Bl's off a sz3000 and a saz 3500. Box was 7.5 tuned to 33. If this is a daily set up then i would not suggest putting more then 1500 on them. Se the amps up correctly and leve the gain knob alone. If everything is set correct you should be able to turn your head unit up all the way and not have any issues other then it being to loud.
