Posted May 24, 201016 yr Hi guys,After lots of research I decided I'd really like to get the Icon 12. I'm most likely putting this in a prefabbed box so I need to make sure it will fit.Does anybody have the magnet diameter for this sub? I see the mounting depth but not the magnet diameter listed on the product page.Thanks!
May 24, 201016 yr Looked for the post but found a tape measure on the desk instead, it is 6.75"edit found thread. Icon Motor - SSA Car Audio Forum
May 24, 201016 yr Author Thanks!I have a followup question. Would 1.25cuft be good airspace for the Icon?My goal is more SQ than all out SPL
May 24, 201016 yr Should be fine, you could always add polyfill to make the enclosure appear bigger to the speaker.
May 24, 201016 yr Author Thanks! That's kinda what I was thinking. In addition to some of the pink stuff around the outside of the box.
May 24, 201016 yr Admin Thanks bromo for finding that info. I took those pictures a while ago, and those are of the last 1st gen Icon (still BNIB), but the slug dimensions have not changed.
