Posted May 31, 201016 yr I am getting ready to build a system for a chrysler 300c and was wondering what you guys think would be louder in this application. 3 sa 12s sealed firing in the cabin or 2 sa 12 ported. I am planning on running a z 2500on the subs.
May 31, 201016 yr I dunno the output of the z2500, so I'm assuming 2500 watts, if you are talking about he saz 2500, then I would do 3 sealed, dual 2 ohms coils, wired in series to 4ohms, then the 3 in parallel for ~ 1.3 ohms.If you do 2, I would do either or both of these few things, build a smaller box, a slightly small flared port, tune low, anything to keep these from unloading too much. Or I'd wire the dual 2 ohm coils in a series parallel to get 2 ohms. If that amps rated power is at 1 ohm.You could get two subs w/ dual 4 ohms coils to get 1 ohm load, but run the risk of damaging the subs (maybe from mechanical before thermal), as they are rated for 600 watts.You could do three with dual 4 ohm coils, wired in parallel to .66 ohms, if you have the saz 2500 and a beefy electrical. (HO alt, big 3, multiple batteries, 0 gauge to the trunk)For burps, but I don't recommend that for a Daily driver, as you be putting a lot of stress on your equipment and something is bound to fail. So, it's your decision, how much money do you have to throw around?
