Posted June 3, 201016 yr Bolt down ring is done for the next production run that will be on it's way to me shortly. It sits on top of the spider insider of the top lip on the frame and bolts in from the back - this way the cone can't come down and smack the bolt heads.
June 3, 201016 yr so do us with the that order the first ones need to make any modifications or should be alright??
June 3, 201016 yr Author so do us with the that order the first ones need to make any modifications or should be alright??If you are running higher than 400-watts RMS you should consider adding epoxy like my tutorial shows :Tutorial: How to strengthen spider landing glue on SA-8 - SSA Car Audio Forum
June 4, 201016 yr so if im running three wired up to 1.33 ohms powered by a sae1200 should i need to do this. dont want to ruin anything by making a mess with the epoxy or damage themo yeah and box will be around 1.3 to 1.5 cubic feet before displacement will know exacty once i get my braces done
June 4, 201016 yr Author so if im running three wired up to 1.33 ohms powered by a sae1200 should i need to do this. dont want to ruin anything by making a mess with the epoxy or damage themo yeah and box will be around 1.3 to 1.5 cubic feet before displacement will know exacty once i get my braces doneYou will be fine. It's quite uncommon for the spiders to come off anyway -- and you are well within the box size and power range.The bolt down is primarily for SPL competitors (like me) who burp 1000-2000+ watts on them.
June 14, 201015 yr would u think 2 of these would be better or 2 truebass ultras? they would be in a box a lil over 2 cubes tuned to 31hz powered by a SAZ 1500 SA-8 @ 1ohm and the trubass @ 2ohms. thanks jacob
June 15, 201015 yr Author I have no specs on the TB ultra at all to go by... so I have no clue.Pricing is still the same on these (not pre-order pricing) -- $129 each.
