Posted June 5, 201016 yr In Meca where less is more. What fusing should I drop down to on an saz 1500? A little more info for my particular install.Amps SAZ 1500 SAX 100x4Power Stock alt 2 yellow tops for a total of 88 amp hrsSubs 3 sa 8'sI would like to run in the lowest class possible Edited June 5, 201016 yr by Soapbox
June 5, 201016 yr any pressure class in 1.Like AS1, S1, M1..With 3 8s, you can run a 35A fuse with that amp.I've ran a 3000w slightly attenuated on a 40A, i've witnessed 6,000w ran on an 80A, I've pulled over 1,100A on 320A, etc....You need an ammeter and proper tuning to get the most out of your amp with a restrictive fuse.
June 7, 201016 yr MECA sound like NASCAR on restrictor plates. In MECA once runs have been completed are the fuses confiscated and verified? If not watch out here I come.
June 21, 201016 yr You can run up to 39 amps of fusing with the surface area you have but you wont find a 39 amp fuse. You can however find and use a 35 amp fuse. I run a 1500 in meca db1 and have ran s1 before on 40 amps. A few of my teammates run a 35 amp fuse and have no problem with it. If you have any other questions feel free to ask and gl!
June 24, 201015 yr Author Thanks for the tips! I have dropped down to 2 SA 8's in a horn, which by the ear is way louder. I have a meter locally and testing will either confirm or deny my ears. I have several items to install 100 sq ft of dampener, hertz energy 165's and a set of zapco components. Soon but not this weekend LAS VEGAS here I come. Correct me if I am wrong but I believe I can configure the following applications with the equipment and boxes I have.Boxes available:T line for 2 8'sFor 3 SA 8's - 1.8 cu ft ported @ 33 with 1 4" aero (this design has already been rejected not enough port) test out at a 134 dbFor 3 SA 8's - 2.4 cu ft kerfed ported @ 35 Cone area's for 8's1= 50"sq2= 100"sq3= 150" sq4= 200" sqFusing for 2 SA 8's possible 50 amp (40 x 100 plus surface area of 100) AS1 class or DB13 SA 8's possible 75 amp (75 x 100 plus surface area of 150) AS 2 or DB24 SA 8's possible 30 amp (30 x 100 plus surface area of 200) AS 1 or DB14 SA 8's possible 80 amp (80 x 100 plus surface area of 200) AS 2 or DB2Sorry but I'm new to competition just covering my bases. Last questionI'm planning to build another t-line box and just double stacking the boxes. Is this advisable vrs just doing another enclosure for the 4 speakers?
June 24, 201015 yr MECA sound like NASCAR on restrictor plates. In MECA once runs have been completed are the fuses confiscated and verified? If not watch out here I come. Fuses are checked before your run. Anyone can fight your score and if you are caught cheating, you will be removed from MECA.
