April 21, 201412 yr Lazy quick workout todayDeads 10x135x1, then 8x225x3Bent over row: 8x100x3close/wide grip pull down 8x240x3, 8x240x3Cable Seated row 8x200x3You got some crazy grip Julian. Why is your dead so small? Bad leg/back???Yeah I injured my back some time ago and haven't really fully recovered yet I was around 305 pretty consistently.Yeah after this my grip is pretty wore outShame. Hope that back gets better.
October 8, 201412 yr Author Admin 5/27TreadmillBenchHammer lat pullCable chest flyPull upsCrunchesElliptical5/29TreadmillPreacherTri pullCrunchesElliptical5/30TreadmillDB pressCable rowMilitaryDead liftEllipticalSide flies5/31DB curlsOver head TriLat rowCable flyCrunchesShrugs6/2TreadmillDB curls/dB rowsLat pullBar curlCrunchesEllipticalTrack6/3TreadmillSide flies/over head TriDecline press/forward fliesLeg raisesDipsCable chest6/5EllipticalDB curls/dB fliesLegs liftsTreadmillLeg liftsCurl machineCable side flies6/9TreadmillTri pull/cable rowLeg raisesEllipticalDead liftReverse press6/10TreadmillBar curls / straight bar raiseLeg raisesElliptical6/12EllipticalBenchDB flyTreadmillShrugs6/13TreadmillDB curlsDead liftCable militaryRun6/16Soccer6/17TreadmillBar curlCable fliesEllipticalLat rowSide flies6/19EllipticalBenchDB curlTri pullTreadmill6/23TreadmillBenchEllipticalCable rowCable flyPull ups6/24TreadmillBar raiseDB curlEllipticalPreacherAbout coasterDB shrug6/25Soccer6/26EllipticalReverse incline benchReverse shoulder cable flyHanging leg raisesCable decline flyTreadmillLat pull calf raise6/29Soccer6/30TreadmillDB side flyDB curlBar raisePreacherTrack7/1EllipticalBenchLat pullCable fliesCable row7/4Hotel mini lift7/7TreadmillMilitary/side fliesCrunchesCable flyCable CrunchesIncline fly7/8TreadmillOverhead Tri press/reverse curlLeg raisesPreacherDipsDead lift7/9Soccer7/10TreadmillPull upsBall twistsEllipticalCable raise/curl/tri/row7/14EllipticalBenchCable row/militaryPull upsDips7/15EllipticalCable fly/rowBar curl/shoulder pressCable dead lift7/16Soccer7/17EllipticalDB curl/dB militaryChest pressPull upsTri pulls7/20Soccer7/21EllipticalCable curl/cable row/cable TriV crunchDB fliesShrugs7/22TreadmillBenchCable rotation/reverse curl/V crunchPull upsElliptical7/23Soccer7/24EllipticalTreadmillDB curls/dB militaryDB rowDead lift/leg raiseMachine chest press7/25TreadmillSide fliesSide leg liftsIncline fliesStraight bar curl7/27Soccer7/28Soccer7/29EllipticalDB benchLeg raisesLat rowForward fliesBar curlDB shoulder press7/30Soccer7/31EllipticalDB curl/standing dB rowDips/legs raisesDelt flies/cable fly8/1TrackBar raise/bar pressTreadmillCable curl/reverse8/3Soccer8/4EllipticalDB benchAb rockerDead liftShrugsBb curl8/5TreadmillBenchPull upsAb twists8/11EllipticalBenchPull upsReverse curlsCable militaryCable curls8/12TreadmillSide fliesShrugsReverse triLeg raisesLat cableTrackElliptical8/13Bar curlCable latCable shouldersCable flyTri pull down8/17Soccer8/18EllipticalDB curl/side fliesTrackPull ups/dipsTrackBenchTrackDead liftTrack8/19EllipticalLat pullTrackBar curlTrackShrugs trackCable flies8/20Soccer8/21EllipticalDB curlLat pullTrack/absBar curlRope curlRowsTrack8/22EllipticalDB militaryTri reverseBar raiseReverse pressShrugForward fliesTrack8/24Soccer8/25EllipticalDB dead liftBenchTrackPull upsSide flies8/26TreadmillDB curlDB militarySquatsDead liftShrugs8/27TreadmillDB benchTrackRowCable fly8/28TreadmillCable curlTrackStraight bar raiseTrackHammer curlOverhead press9/2TreadmillDB curlDB flyTrackBench9/4EllipticalSide fliesCable latTrackCable shoulderKneeling rowReverse flyTrack9/5EllipticalBar curlSeated curlTrackHammers9/9TreadmillBar curlPull upsTrackCable curlRowtrackReverse curl9/11TreadmillSide fliesSquatsShrugsForward fliesTri pull downs9/15EllipticalBar curlLat rowTrackDB curlLat pullTrack9/21Soccer9/22EllipticalIncline dBDead liftBenchCable row9/23TreadmillBar curlSeated militaryHammerSeated forward fliesReverse curl sSide cable flies9/28Soccer9/29TreadmillBar curlMilitary DBTrackDB curl9/30EllipticalDB flyPullupsIncline benchDead liftSoccerPull upsShrugs10/5Soccer
October 8, 201412 yr Author Admin Too many feet exercises Is that Michigan for cardio? too much soccer For me, never too much. I will keep playing as long as possible.
October 18, 201411 yr After a little planning alterations, I've fallen into a regular schedule four days a week. 6'0", 168 lbs. Saturday: upper body w/ core and cardioPushup, curls, tricep press, bench, db bench, pullups, lat pull downs, plate raises (bench and lat pull downs are usually de-loading sets)20 minute runweighted russian twists, weighted sit ups, leg raises, planks Sunday: Lower body w/ core and cardioDead Lift, Squats, Calf extentions, Lunges, hip raises20 minutes runweighted russian twists, weighted situps, leg raises, planks Monday: repeat saturday Wednesday: Full BodyCurls, tricep press, plate raises, lat pull down, bench, dead lift, squats, calf extentions, butterfly10 minute runrussian twists, situps, leg raises, planks The three days I miss are due to not having time, and the full body day is to hit all the muscles I didn't due to the skipped Tuesday, as sort of a catch up day. I'm thinking that I need to mix up the core exercises a bit.
November 7, 201411 yr So, meant to post up yesterday at work what I had done, as I was working a 16 hour shift.But then we had an arseho acting up because we wouldn't give him extra time on the phone...So at lunch yesterday I worked back, then did shoulders after supper.Back: 4 sets of eachOutside grip lat pull downsSeated cable rowsDeadliftsBent over dumbbell rowsInside grip pull downsShoulders: 4 sets of eachStanding upright barbell pressBarbell ShrugsSeated dumbbell pressNot sure of correct name, use cable machine lifting bar from waist to chin in standing positionDumbbell raises (front and side in same set alternating)I use my breaks at work to go to our staff gym. At most I get an hour to work out at a time and aim to fit 4 excercises per workout, doing a 12 rep warm up, and 3 ten rep training weight sets per excersise done. And isolate one muscle group per workout.Have just started getting back into working out this past month. It feels awesome. Edited November 7, 201411 yr by nigel
November 8, 201411 yr On vacation at great wolf lodge with the FAM. Last night used the resort fitness room for a bi/tri workout. No free weights, just machines. Did 4 sets, regular and reverse grip bicep curls, both 2 handed and single, as well as same for triceps pull downs (cables).
November 9, 201411 yr So, just going to bed after doing a quick leg workout. Still at great wolf lodge, so limited to what they have...Started with a 10 min warm up on the elliptical.Then leg press machine. Warm up at half stack for 15 reps. Then 4 sets of 12 reps full stack. Didn't pay attention to the weight... Just knew it wasn't near enough.Followed up alternating walking lunges the length of the fitness room both directions then 15 calf raises, for 4 sets of each.4 sets of squats, at body weight, holding at bottom for a 10 count.Finished on the bike at the highest resistance, standing. Edited November 9, 201411 yr by nigel
November 9, 201411 yr I need to start working out again! I have been able to do limited workouts since my shoulder surgery ac4 seperation..when I first started back doing push-up I could only do maybe 50 or so and I was done..LOL While I was off work I did get up to anywhere from 500-700 daily..Until I went back to work..then I fell of still nervous of trying free weights again..I thought I would never be able to work again because I had 100% numbness like my arm had fell asleep for months till about 2 weeks after my surgery all i could feel was my thumb.
November 10, 201411 yr chest day at work. Lunch Break routine. 4 sets of each.Flat BenchDecline BenchIncline DumbellCable Fly
November 12, 201411 yr 16 hr shift day today. So back/shoulder split dayLunch time: backOutside grip pull downsSeated cable rowBent over dumbbell rowInside grip pull downsStanding cable high row (upper back/shoulder)Evening: shouldersSeated dumbbell pressBarbell shrugsStanding barbell pressStanding vertical cable row Edited November 12, 201411 yr by nigel
November 12, 201411 yr Author Admin I'm going through a system shock routine, as Neal has me trying 101's. I'm going to ride it for a few weeks and see how things go.
November 15, 201411 yr Chest day.Incline barbellFlat dumbbellPec deckCable flyMy big ass did some 12 oz beer curls today..And tore the door frame all to hell when I tried to do a pull-up on one of those cheap ass door frame pull-up bars..Not for a 270 lb adult..lol
November 16, 201411 yr Hate those things. Way to many people get injured from them. Unfortunately most people don't have the space or spot to put a proper pull up bar/rack in.I am lucky, in that we have a wellness center at work with a selection of equipment I can use on my lunch breaks.
November 16, 201411 yr Hate those things. Way to many people get injured from them. Unfortunately most people don't have the space or spot to put a proper pull up bar/rack in.I am lucky, in that we have a wellness center at work with a selection of equipment I can use on my lunch breaks. I agree.. i tore the whole top of the door frame off and I busted my ass as well
November 16, 201411 yr double toaday.Lunch Back:Deadliftsseated cable rowoutside grip lat pulldownsBent over Dumbbell rowSupper Shoulders:Seated Dumbbell pressStanding vertical rowDumbbell raises (to the front and sides alternating)standing Barbell PressShrugs and standing high row alternating
November 18, 201411 yr Arms.Preacher curl and overhead triceps extension, alternatingStanding cable curls and cable triceps pulldowns, alternatingOne handed bi curls and tri pull downs, alternating regular and reverse grips.Did 6 sets of everything.
November 20, 201411 yr Chest. At home today, on a 5 day off stretch. Working out with the six year old as a "spotter"Flat benchIncline dumbbellDumbbell fliesPush upsAnd just for fun did some light weight squats alternating with my flat bench sets.
November 22, 201411 yr At home work out. Back day.Lat pull downsBent over dumbbell rowDeadliftsReverse grip bent over barbell rowInside parallel grip pull downs alternating with calf raises for fun
November 23, 201411 yr At home again. ShouldersSeated dumbbellVertical rowStanding barbell press alternating with lungesShrugsStanding Dumbbell raises alternating to the front/sides in same setsSitting on edge of bench bent over dumbbell lifts from under legs out to the sides. Edited November 23, 201411 yr by nigel
November 29, 201411 yr I can't be the only one who lifts on here. Someone else post up your routines. Mine are boring due to equipment/time restraints.I stick to the kiss principle.Yesterday: chestFlat benchIncline dumbbellCable pressPec deck/fly machineToday: backOutside grip pulldownsSeated cable rowBent over dumbbell rowReverse grip pulldownsHigh cable row
