Posted June 26, 201016 yr Will SA-8's perform well in a sealed box for midbass (80hz-250hz)?I honestly have no idea what makes for a good midbass driver vs subwoofer.any input would be appreciated
June 26, 201016 yr I saw someone on another forum running SA-8's in the doors for midbass, but I think I remember Jacob saying they weren't really made for that.
June 26, 201016 yr Author I saw someone on another forum running SA-8's in the doors for midbass, but I think I remember Jacob saying they weren't really made for that.I'm assuming because the drivers are designed to reproduce lower frequency? Well I'm interested in getting some wicked midbass. Guess I'll go check into j-roadtatts build log
June 26, 201016 yr well there actually pretty heavy drivers and there rated for 400 rms so i dont think you will be running 400 to each driver just for midbass. The E8 might be better for that
June 26, 201016 yr Author On the previous post talking about having them in the doors, they were most likely a IB setup, so maybe sealed would work?as for how much power they take, If I ran 800watts for midbass, I'd just have a lot of midbass I'll look into the E8, thanks
June 29, 201016 yr You can make em' fit. The 20 lbs is only noticable for the first couple days. I think SA-8 would work great for a midbass. If you like heavy midbass then your on the right path. I don't think the SA-8 likes being sealed though, SO stick with IB of the door.
June 29, 201016 yr Author You can make em' fit. The 20 lbs is only noticable for the first couple days. I think SA-8 would work great for a midbass. If you like heavy midbass then your on the right path. I don't think the SA-8 likes being sealed though, SO stick with IB of the door.hmm, I'll probably put them behind the seats, maybe in small ported enclosures then?
July 1, 201016 yr As long as you don't expect output above 200-250 Hz they would work okay as midbass. I think my distributor told me someone is doing it in Russia and they love it.
July 1, 201016 yr Author sweet, perhaps ill order them later when there available and I can afford it
July 1, 201016 yr Would those still need to be ported to be efficiant. I guess tune at a higher freq.?
July 1, 201016 yr Would those still need to be ported to be efficiant. I guess tune at a higher freq.?For mid-bass duty you would be fined sealed or IB on them. If you did port them for midbass tuned high it would be sick.
July 1, 201016 yr Author Would those still need to be ported to be efficiant. I guess tune at a higher freq.?For mid-bass duty you would be fined sealed or IB on them. If you did port them for midbass tuned high it would be sick.how high of tuning are we talking about? 80hz?
July 1, 201016 yr 0.25 tuned to 60 or so... would net a huge amount of output in the lower midbass 50-100 Hz.Would actually have to purposely EQ them down for a flat response - but most folks like huge midbass output especially when pairing to big woofers.
July 1, 201016 yr Author Is this going in one of your jeeps?planning on it, going behind driver and passenger seats
July 1, 201016 yr 0.25 tuned to 60 or so... would net a huge amount of output in the lower midbass 50-100 Hz.Would actually have to purposely EQ them down for a flat response - but most folks like huge midbass output especially when pairing to big woofers.Thanks!
July 1, 201016 yr Author Okay Im not sure if youll read this Jacob, but you were in so figure its worth a shot. I ordered some sa12's a few months ago but they got on backorder so I canceled, but they got sent anyway and fedex tried delivering them yesterday but I wasn't here to sign for them.Mark said you were going to try and get a hold of fedex and have them rerouted back to you. did you ever get a hold of them?I just want you to get your merchandise back and I'm not sure if Fedex is still trying to deliver them or not.my address is 7461 e calle iluminacion tucson az 85715 (if this helps)
July 1, 201016 yr Author Yah, Mark got in touch with me and the subs were re-directed.okay good, one less thing I need to worry about
