Posted July 13, 201015 yr So I got my 2500D, and I just realized that it doesn't have an internal fuse. So what to do? Fuse the + lead about a foot from the amp? Why doesn't it have a built in fuse anyway? Just wondering.
July 13, 201015 yr So I got my 2500D, and I just realized that it doesn't have an internal fuse. So what to do? Fuse the + lead about a foot from the amp? Why doesn't it have a built in fuse anyway? Just wondering.Thats about right i belive. atleast i did it on my brothers amp, which is an ground zero 1800w rms...
July 13, 201015 yr So I got my 2500D, and I just realized that it doesn't have an internal fuse. So what to do? Fuse the + lead about a foot from the amp? Why doesn't it have a built in fuse anyway? Just wondering.Because it needs 250 amps of fusing - that is alot of fuses to put in an amp Also it is an SPL competition amp and when you run an amp down really low it tends to blow internal fuses.Yes, fuse it shortly before the amp.
July 13, 201015 yr Author So I got my 2500D, and I just realized that it doesn't have an internal fuse. So what to do? Fuse the + lead about a foot from the amp? Why doesn't it have a built in fuse anyway? Just wondering.Because it needs 250 amps of fusing - that is alot of fuses to put in an amp Also it is an SPL competition amp and when you run an amp down really low it tends to blow internal fuses.Yes, fuse it shortly before the amp.Ahhh I SEE! lol, I'll be running the SAZ 2500 along with the SAX 100.4. So should I fuse my power wire off of my battery under the hood with a 300 amp fuse assuming i'll have that amperage available? (which I won't until I get an alternator, but i have a Deka Intimidator 9a31 in the back for now). The real question is can you starve your amps of power if you don't have a big enough fuse on the power wire? Edited July 13, 201015 yr by Im Hung N ur Not
July 13, 201015 yr nope you will just blow the fusing, if you feel you need 300a then do it but if jacob says you can do 250a then thats what i would do man
July 13, 201015 yr Author nope you will just blow the fusing, if you feel you need 300a then do it but if jacob says you can do 250a then thats what i would do manWell yea, a 250 by the amp and a 300 coming off the the battery under the hood. Just for the fact that i'll be running the 100.4 off of the same power wire
July 13, 201015 yr nope you will just blow the fusing, if you feel you need 300a then do it but if jacob says you can do 250a then thats what i would do manWell yea, a 250 by the amp and a 300 coming off the the battery under the hood. Just for the fact that i'll be running the 100.4 off of the same power wire thats just fine.
July 13, 201015 yr Yeah that 300A should be fine by the battery since your highs amp wont be pulling that much amperage when playing and your sub amp wont be at 300A all the time neither.
July 13, 201015 yr fuse for your wire at the battery, if you have 1/0 that is only good for 250 amps @ 20' fuse for that, if you have some really nice OFC 1/0 that should handle ~375 amps. then the power for the amp fuse for the amp, then fuse the 4ga going to the 100.4 if you want but should be fine with its fusing. all ways fuse for your wire then you can step it down as you need.
July 14, 201015 yr Author To bad my I'm cellphone-less and you can't text me. lolDamn, I forgot.. I been sending you texts.. lol let me know when you get your phone
July 14, 201015 yr Author fuse for your wire at the battery, if you have 1/0 that is only good for 250 amps @ 20' fuse for that, if you have some really nice OFC 1/0 that should handle ~375 amps. then the power for the amp fuse for the amp, then fuse the 4ga going to the 100.4 if you want but should be fine with its fusing. all ways fuse for your wire then you can step it down as you need.OFC 1/0? What does OFC mean? I have Streetwires 1/0. Will OFC be printed on the insulator coating of the wire if it is indeed "OFC" wire?
July 14, 201015 yr it should be if it is, OFC is Oxygen free copper, or 99% copper. other wise its CCA (copper clad aluminium) witch doesn't handle the same amount of current. you may want to look up your wire and see what they rate it at.
