Posted August 2, 201016 yr Hi guys need your help here, would you recommend the SAZ 1000D or SAX 1200D to drive 1 Fi Q 12 Dual 2 ohms (1000 watts RMS) in a ported enclosure?I been doing some reading which indicated that, it's been recommended that the amp should be higher than woofer's RMS so I decided to ask the experts.Thanks,Shopvac. Edited August 2, 201016 yr by Shopvac
August 2, 201016 yr Admin Side note: the 1000D is no longer in stock and is not returning. The SAX-1200D is more then enough amp for the Q, and since you are not trying to dip below 1ohm, it will be a great choice.
