Posted August 5, 201015 yr I was driving around and all of a sudden my btl quit. I have tried to rewire it using just one voic coil and noluck it wont even turn on... Any idea?
August 5, 201015 yr DMM check coils, check wiring. Is your amp not turning on because subs don't "turn" on or off?
August 5, 201015 yr Author DMM check coils, check wiring. Is your amp not turning on because subs don't "turn" on or off?I pushed on the sub it moves freely. I had tested the amp with another sub and it works. The wiring going in is fine. Could it just be somehow both terminals got fried?
August 5, 201015 yr Pushing on the cone can only tell you that there's no noise from coil scratches. Get the DMM and read the coils. Get the sub out and look at the tinsels and check for physical anomalies.
August 5, 201015 yr Author Pushing on the cone can only tell you that there's no noise from coil scratches. Get the DMM and read the coils. Get the sub out and look at the tinsels and check for physical anomalies.How do you read the coils?
August 5, 201015 yr Get a Digital Multi-Meter (DMM) and put the probes in the coil and test the coils, make sure you have the DMM on the right setting as well.
August 6, 201015 yr Where was your subsonic filter set? Gains? Volume knob? Any bass boosting features on the amp or headunit?People rn upwards of 4kw to a BTL and never have an issue..the only time there is a problem is due to somebody having something set up improperly.
