Posted August 18, 201016 yr System:(3) SA-8 D4'sPhoenix Gold ZX600.2 titanium. (1200W @ 2 Ohm bridged)Looking for help designing the box for these bad boys. I've don't see any information on the Sundown site regarding recommended volumes / port sizes / tuning, so here I am... I've played with WinISD some, and basically decided to tune it somewhere around 33 Hz.For those of you that have these bad boys, what tuning do you run, what volume of box, and how many subs?For my build I'm thinking of going with .6 cubes per sub (chambered box) with a slotted port that is 5" x .75" x 16" (slot port inside dimensions). From what WinISD tells me this should be sufficient to run @ 33 Hz tuning, but I want input from the guys that actually have these. Also can someone tell me how you factor in a slotted port into box volume? Do you just subtract out the wood and count the air space as part of the box volume, or completely subtract out the entire volume of the port?I plan to start building Friday afternoon. Edited August 18, 201016 yr by Criss
August 18, 201016 yr Author I would go about 1.5=1.8 cubes net @ 33hzSingle chamber, or 1.5 per driver? I don't have the space to afford a 4.5 ft3 box in my trunk for some 8's if you're talking about per driver.
August 18, 201016 yr Im pretty sure that is the volume for the three drivers together in a single chamber instead of individually.
August 18, 201016 yr Author Im pretty sure that is the volume for the three drivers together in a single chamber instead of individually.Is that the best approach? A single chamber box rather than splitting them into their own chambers.
August 18, 201016 yr Im pretty sure that is the volume for the three drivers together in a single chamber instead of individually.Is that the best approach? A single chamber box rather than splitting them into their own chambers.It doesnt make a difference really, the only downfall of using a single chamber is that if a driver fails you wont be able to play them other two until you get it fixed.
August 18, 201016 yr Author Im pretty sure that is the volume for the three drivers together in a single chamber instead of individually.Is that the best approach? A single chamber box rather than splitting them into their own chambers.It doesnt make a difference really, the only downfall of using a single chamber is that if a driver fails you wont be able to play them other two until you get it fixed.Next Question:Tuning - is 33 Hz a good place to be, or should I go higher or lower?
August 18, 201016 yr It depends if it is for daily, competing or purely spl. I know Jacob recommends 30Hz for the 12"s but you dont have to use that tuning. If for daily then 33hz will be fine.
August 18, 201016 yr Author It depends if it is for daily, competing or purely spl. I know Jacob recommends 30Hz for the 12"s but you dont have to use that tuning. If for daily then 33hz will be fine.Yes, daily use. Looking to get the smoothest response from them. My overall goal is for SQ not brain rattling bass.The only other question I haven't seen answered is:When calculating the box volume do you subtract out the entire port volume, or just the material used making the port?
August 18, 201016 yr It depends if it is for daily, competing or purely spl. I know Jacob recommends 30Hz for the 12"s but you dont have to use that tuning. If for daily then 33hz will be fine.Yes, daily use. Looking to get the smoothest response from them. My overall goal is for SQ not brain rattling bass.The only other question I haven't seen answered is:When calculating the box volume do you subtract out the entire port volume, or just the material used making the port?Than just one sa8 would be fine.Subtract the whole port volume and material. also you need to subtract the driver volume. for the sa8 its about .10 cube per driver
August 19, 201016 yr i have 2 sa-8's in a ext cab s10, my box is 1.4 cubes, with a single 4" aero port, but external, ive tried 30 hz, 35 hz and 38 hz, so far, 38 hz has been the loudest. even playing down real low, 38hz port was louder, i just dont think these have the cone area to get loud at such a low hz.also, im running a saz 2k at 2ohms, so 1000 watts to them Edited August 19, 201016 yr by Hostility
