Posted August 30, 201016 yr So I got on it today getting on the interstate, battery light came on, stayed on a few seconds then went off. Put it in neutral, reved it, nothing for a few seconds, stopped reving, light came on a few seconds. Pulled over, put DMM on front battery 14.18. Reved it up, droped to 13.2...stereo off. Checked rear batts, 14.18 running, dropped to 13.5 off, probably would have kept dropping slowly.O'Reilley AGM in front, 2 large O'Reilley AGMs in back 100aH. Iraggi HO alt, the highest at idle lowest peak: 160-180 idle, 200-220 peak.
August 30, 201016 yr check each batt individually several hrs after vehicle was last turned off for accurate rest level.either one or more of ur batts is REALLY low or u may have burned a diode out in the alt.
August 30, 201016 yr Check the pulley on the alternator for particles of belt (specks of black coating) as you may be slipping and not knowing it or it may not give signs (squeals). Or bad alternator.
August 31, 201016 yr Author I had to get a smaller belt since the pulley is smaller, and I got the high quality one knowing Id have a slightly tougher load. The belt doiesnt seem to slip. I know Iraggi is revamping, think Ill have any luck calling?
August 31, 201016 yr Take alt to a auto parts house just for a load test. That way you will know what you are dealing with. just a suggestion, Thanks ...
September 3, 201016 yr Author I went to Van's today, the local rebuild shop. The guy took the big ass DMM to my battery to confirm the voltage drop, told me to pull it and bring it in for a real test, and get this shit: He told me not to add alts but add batteries! So yup, Ill go to Advanced and O'reilleys now made a vid showing the drop on the van's voltmeter while driving. I dont hear any squeel, it happens even at low RPM...
September 3, 201016 yr Author Went and load tested the alt, only doing 99A (rated 160-200A @ idle 220 peak above 1500 RPM) and tested the batteries, theyre all good. Guess I gotta get ahold of Iraggi and see if it's a warranty issue. yay!
September 3, 201016 yr Unless you live down the street from Iraggi, I doubt you're going to be able to get a hold of him. Good luck though.
September 4, 201016 yr Author Unless you live down the street from Iraggi, I doubt you're going to be able to get a hold of him. Good luck though.thats what Ive been afraid of... been emailing for months about ordering 2 more alts, and now twice about this...no reply, nor on FB siteIsn't 99A the biggest amount of amps tehy can measure? shrug i have no idea
September 6, 201016 yr Author pulled the Iraggi today, was gonna drop the stock back in so I have a vehicle to drive till I get it repaired and order a 2nd alt. The stock one has been sitting on a shelf in the basement since I pulled it. it didnt get wet, but it's been humid. The damn thing rusted and I cant even spin the pulley! Now what the f do I do? I am stranded at home, cant get ahold of Iraggi.
September 6, 201016 yr hehe. What do you do? Call DC power.No, really. They may be able to help you. They will help even if you don't buy anything.
September 7, 201016 yr Author hehe. What do you do? Call DC power.No, really. They may be able to help you. They will help even if you don't buy anything.email sent I emailed them 2 weeks ago and talked to Kevin about a bracket. Thank you!I know a lot of people are gonna talk ****, but 4 separate forums have said the same thing. But it never fails, anything I do, so many people think they gotta say sumthin stupid and when I get mad Im told not to over react. I was told to spray her down. So I did. Do I need to use anything to remove it from the pulley after it sits over nite?not sprayed yet, wood that got wet previouselynot sprayed yetsprayed
September 7, 201016 yr You meant Kyle, right? I don't think there's a Kevin at DC Power. Good luck though. Hopefully it works again after.
September 9, 201016 yr Author brought the HO alt and the stock alt back to Vans, talked to the owner this time. What a difference. We had a blast going back and forth, guy knows his shit. The brush tensioner spring went bad. He replaced the assembly for me and I gave him my stock alt. I know he came out ahead, but my HO alt works great so I don't care!
September 10, 201016 yr Author Glad to hear you got your problems situated. Thank you! And thank you all for your advice!
