I currently have 2 db drive platinum 12s on an Alphasonik PMA600HCA that is rated at 1800rms and I was wondering if the Fi BL12 would do good on this amp or should I look into a different amp or woofer?
Its fine if your db drive subs can take it. be smart with the gain and no bass boost. subsonic filter would help a lot too if you are going to use a ported box.
x2, but if your worried then get a 12" BTL since there is no such thing as underpowering a subwoofer but either way you will be fine.
