Hello i have a small question when strapping 2 1500d's is 26 inchs to far about will it hurt performance i am having alot of trouble fitting everything in my hatch was hoping to stack the amps but just dont have the room so i was wondering if i could put 1 on each side of the box and still keep them strapped or if i should just divide the box into 2 chambers and run the amps unstrapped would like to get some you guys opinions
I would think it would be fine, make sure your grounds are short as possible, you could do two runs of speaker wire to be on the safe side...
i would NOT make them that long maybe 14 at most, mine are about 3inch..
could you maybe fit them on top of the box? that way you can make the box wider and less tall to fit the amps? or how about stacking the amps on ONE side of the box? that idea could work if you do something as shown in this pic!
please note on the pic that the 2-sae1000 are stacked with a solid piece of steal (3/8 round stock i believe) and that piece of round stock has 2 tapped holes, 1 on each side that way they screws will screw in tight and maybe use some lock tight also
other then that if you want to run 26inch maybe step up to 4awg wire and use a 4-8gauge reducer? although that might be a bit over kill but better to be safe then sorry maybe?
i dont even have close to that much room i take some pics in few mins and show yah theres no way possible i can get 2 stacked
you don't have room... although you have room to put 1 on each side?
Okay its to dark for pictures tonight but i have a 1998 eclipse with 4 10's in 5cube box 2 deka batteries 1500d and 100.4 all in the hatch and its TIGHT squeeze i am ordering 4 sa-10's so wanted to get another 1500d cause i dont believe 1 will do them justice
the box has to remain same size currently they are all 4 firing up would it hurt my sound very much if i put 2 subs on each side of the box with port straight up then i could mount amps on top side by side
just measured and i only have 8 inchs on the 2 sides and 6 in front so thats why i casn put one on each side but not enough to stack 2
hey don't count out the 1500d lol! have you considered just upgrading the amp to say a 2500 or 3500 or one of those 3000's?
not counting it out one bit i love the one i have now but you know how it goes always want more lol and i already have 1 1500 and can get second pretty cheap so thats why i was going that way dont really have the cash to buy a bigger amp
o i c! well for sure get some pics up tomorrow and i am sure myself or someone else could think of an idea you missed! jsut be sure to get some nice shots of looking down, look from the front and looking from the back.. hatch back car?
and i for sure know what you mean about bass it is addicting lol hell i got 2-saz2500 lol and now i wnat 2-3500 lol
front is no good not enough room to put then side by side or stacked
heres right side battery is there currently but i can move it around to front
Amp is 17 inches plus room for connections and at about 16.5 shock tower moves in to about 3 inchs
umm ya a little tight for space could you please take a pic of EVERYTHING those zoomed in pics are a little tuff to make out where in the car they are. maybe stand on the back bumper and get a good GOOD (not blurry) top down view for use to see. also how much room down you have from the glass to sub/box?
Why?
Why?
I don't see what the big deal is...
when i asked Jacob this question when I was strapping my sax1000d amps he told me to keep the strapping wire as short as possible to elimate issues and what not... I wish i had the e-mail saved b/c i know he went into a little further explanation of it. so with that i just have always keep my strapping wire as short as possible and plus 12inch seems excessive to me.
got a reply from jacob on this already its fine to run them that far apart just need to run at least dual 8awg wire
You want them as close as possible as a large amount of current passes between them -- if you space them apart 26 inches do not use anything smaller than dual 8 awg runs between the amps.
- Jacob
aww ic! thanks for posting that! i guess i was mixing up info a bit.it has been awhile since i asked him that question lol
