September 13, 201015 yr No, I don't, but I know that mine barely moves off 500 ish watts and I did a 139.2 today.I would guess once broken in probably 20+ with as big as the coil is and how tall the motor is.Kef
September 13, 201015 yr I think it would be safe to assume 30" XmaxJust realized i put 30" I meant 30 mm
September 17, 201015 yr Admin I think it would be safe to assume 30" XmaxThat is quite a large amount, how do you know?
September 18, 201015 yr I think it would be safe to assume 30" XmaxJust realized i put 30" I meant 30 mm I think it would be safe to assume 30" XmaxThat is quite a large amount, how do you know?That's what i meant Most performance woofers have around 30 mm of xmax, the icon, xcon, btl, etc pure assumption
September 18, 201014 yr interesting,.....throwing around 30mm like its average or something. if i had to guess, id say it ranges around 21-26, but thats purely speculation at this point
September 18, 201014 yr interesting,.....throwing around 30mm like its average or something. if i had to guess, id say it ranges around 21-26, but thats purely speculation at this pointthis is out of something i've noticed, xcon = 31 mm xmax, BTL = 28, Nightshade around 30.Maybe i'm 100% wrong, but this seems common on high performance woofers like these.
