August 8, 201115 yr Author Did a bit of tidying up, moved the amp from the trunk to the folding seats, bought an el-cheapo wiring kit from wallyworld.My Two dekas Preeeety. Jacob makes some sexy amps :wub:
August 9, 201115 yr Author Crikeys, noice! Anything to secure those batteries?I'm planning to get a heap of expanding foam from tap plastics and fill it while the batteries are in there in black trashbags
August 9, 201115 yr Author Trash bags and a lot of them will help keep the form and allow it to be removable
August 9, 201115 yr Crikeys, noice! Anything to secure those batteries?I'm planning to get a heap of expanding foam from tap plastics and fill it while the batteries are in there in black trashbagsInteresting idea!
August 9, 201115 yr I know where you got the trashbag idea from, thats what I plan on doing to secure my batteries to the wheel well. Love those Sundown amps, makes it hard to switch to other companies. I wish I had some seat backs to install my mids/highs amp to in this car, looking good so far. Any room on the other seat for the DD amp to fit?
August 9, 201115 yr Author Pretty much, The height of my trunk opening from the rear folding seats is around 10" but there after it drops off to probably 17", I'm going to make the box to the full back of the trunk so it touches and jack it up with some bolts and make the underside where i'll place my amps
August 9, 201115 yr Author Ok sounds like a plan, no more walling for you huh? I got talked out of it plus i have no one to help me on a wall.
August 9, 201115 yr Ok sounds like a plan, no more walling for you huh? I got talked out of it plus i have no one to help me on a wall.I definitely hear that, i been going back and forth about a wall in my car as well but then I sometimes think Id rather get an SUV and put that same equipment in there without a wall. Well let me stop babbling and turning this into a chat thread.
August 10, 201115 yr Author Ok sounds like a plan, no more walling for you huh? I got talked out of it plus i have no one to help me on a wall.I definitely hear that, i been going back and forth about a wall in my car as well but then I sometimes think Id rather get an SUV and put that same equipment in there without a wall. Well let me stop babbling and turning this into a chat thread.it's all good, Same here, but a wall in a 2 door car is a dream of mine honestly lol
August 12, 201114 yr Author did a bit of aesthetic work today, LED's or a fan with LEd's are comingPReeeety
August 12, 201114 yr Looks great!!! Now if it was flush mounted on a plate of some sort, along with the LED fans you spoke of SICKNESS!!
August 12, 201114 yr Author Looks great!!! Now if it was flush mounted on a plate of some sort, along with the LED fans you spoke of SICKNESS!!That's what i'm thinking but its all up in the air, UGPM btw
August 12, 201114 yr Looks great!!! Now if it was flush mounted on a plate of some sort, along with the LED fans you spoke of SICKNESS!!That's what i'm thinking but its all up in the air, UGPM btw Guessing what your sub stage consists of will be a desider of how you can display the amps...Got the PM- Thanks!
August 12, 201114 yr MMM M3 power. I went and scoped out a bunch of the lower level DD stuff again yesterday at one of the local shops. They offered to buy my M1b for more than I paid for it. I must have gotten a great deal. That M3a should look sweet with the plexi cover.
