Im sefugis addopted son so what do you guys think about anouther fathe / son build by the master Gi 68 members have voted
  1. 1. who wants to see this build happen
Please sign in or register to vote in this poll.
  • Replies 261
  • Views 39.1k
  • The steering shaft should work now, hated to beat up these headers , its just how it is. By grasshoper at 2010-10-10 Had to trim back the slip sleeve on the shaft, and round down the inner shaft with
  • summit came through with the wrong radiator hose, but they overnighted the correct one with clamp and a water neck 90 degree swivel, pics to come after install and maybe a teaser video,
  • OK guys I cracked into grasshopper's pictures and this is what I found that he hasn't posted. I knew more had been done but the pictures havn't shown it. No disrespect, but the story has to be told...
Looking good fellas!When can I bring the Yukon down for a LQ9 swap?
Probly in March, got lots to do on this build and still have a wall to build.
:dancing: :dancing: :dancing: keep it up. looking good so far
Got lots more comin'!!!!
delivery came, fuses , fuse holders, picked up some misc. zip ties , heat shrink, solder, and all the goodies needed to make stuff happy.
started making some connections, decided that since the entire wire harness was coming out why not use all 1/0 grounds, and do a little upgrading!!!
Passenger side of engine bay is cleaned up and back in, Battery tray and first battery is installed , fabd a plate for the fuse holders to mount to , and started running some of the 1/0 connections,
You can see in the background of this pic the control module for the fan assembly
not sure about the fuse holder mount , made it from some extra material, but not sure Im feeling the squareness, I just dont know if Im feeling the flow of it , ideas or opinions ?
spread the fuse holders farther apart and put a airbrushed grasshopper in the center of the mount... or something eye appealing
  • Admin
Should we pin another sefugi build log?
Havn't gotten to the other side but there are 2 more of those fuse holders that will be going on the opposite side. The grasshopper sounds good! :drink40:
At the rate he is going, Sefugi will need his own section.
:drink40:
:doit: :doit: :doit:
:fing34: Another build might be starting soon!!!!!! Grasshopper pushed Sefugi into buying another vehicle for a wall, will pass on the details if deal goes through Wednesday.
At the rate he is going, Sefugi will need his own section. :drink40:
:woot::lol2:
Need to make more progress first!!
  • Admin
:trippy: :trippy:
  • Admin
:drink40:
:lol:
:drink40:
:lol:
x2 :roflmao: Keep up the good work, engine bay looks killer :fing34:
yeah thinking about some plate aluminum from a scrap pile, might cut out a spade or something , not sure? might put a grasshopper mural in the hole for the old air cleaner made from a circle of lexan, well see come wednesday / thursday Ill be back on it and hopefully she will be breathing fire soon!!
Just an update... Spent some time tonight making some progress. Thinking Grasshopper will show a few pics of what has been going on, he's got the camera and the pics. Things are coming together under the hood. Tomorrow night we will start attacking the wiring harness, got a lot of things to trim out and many more to add. Lots of solder and heatshrink to burn. :trippy: Still waiting on a few things to come in to tie up a few loose ends on plumbing. Stay tuned for some updates with pics.
EPIC!!!!!
Engine compartment is starting to shape up, need Grasshopper to get some pics up to show our progress!
progress update, last post was not feeling the fuse mount on the passenger side , it was not gonna work so after some scrap hunting decided to go with some plate aluminum.
By grasshoper at 2010-10-21
decided to try my hand at some detail work on the plates with a cordless drill and wire brush, looking for a scalloped pattern
I like these mounts better than the previous ones, fuse holders mounted, fuses installed were going hot
got the twin e-fans and radiator permanently mounted, all wired , soldered , and shrink wrapped, man sefugi has got a super clean sense of flow when it comes to wiring, routing, painting, installing flux capacitors, you name it if hes involved , half ass wont cut it its either ready for the judges to inspect or its nothing!
gonna button up some loose ends tonight, and get started on the wiring harness if all goes well .
Very nice progress gents!
:popcorn:
Thanks!!!! Now that the order has shown up, we will try to get the plumbing completed tonight and then move on to the wiring harness.
