Posted September 24, 201014 yr i completely removed everything behind the front seats to get ready to put in some damplifier pro and found out my trunk already had some pieces of sound deadener that came from the factory. i was just wondered if it would be better to remove it or just place the damplifier pro on top of it? Edited September 24, 201014 yr by ML91
September 25, 201014 yr i completely removed everything behind the front seats to get ready to put in some damplifier pro and found out my trunk already had some pieces of sound deadener that came from the factory. i was just wondered if it would be better to remove it or just place the damplifier pro on top of it?depends on the type of deadener. does it do an effective job? thump on the panel next to it and compare that to a properly dampened panel with damplifier. on my nissan the dampener is very plasticey and brittle. it doesnt do a good job and comes off relatively easily with a scraper. so in my case, i would remove and apply damplifier in its place.
September 25, 201014 yr Definitely remove it. You need to attach to the parts you want to constrain.Do yourself a favor and look at the SDS products and ask for recommendations before running out and buying SS. (link in my signature)
September 25, 201014 yr Definitely remove it. You need to attach to the parts you want to constrain.Do yourself a favor and look at the SDS products and ask for recommendations before running out and buying SS. (link in my signature) The stock deadener should come off very easily, it did in my new car and it's a brand new car.all you need is a bench scraper and some denature alcohol to remove the residue.
September 26, 201014 yr I'm constantly amazed at the low quality of the stock materials used, even in relatively expensive vehicles. Some will have decent stuff on the center tunnel and then cheesey asphalt based coatings everywhere else. I've seen thick layers of plain asphalt, coated asphalt sheets that go through the paint bake (very common) and even asphalt impregnated cardboard that was falling off on the roof a Dodge pickup that was falling off after 6 months. Some of these things seem to have been designed to get you through the test drive. The asphalt on the floor of an Hummer H1 had turned into a stringy goo that I cleaned off with a plastic ices scraper. Except for the rock hard, backed on material that is meant to stiffen panels, I'd suggest removing whatever stock material you can.As ///M5 said, do not bother putting aftermarket damper on top of either stock damper or other layers of aftermarket product. It has to be in contact with the panel to work. Additionally layers are damping the layer underneath, more than the panel itself. I wish I'd know this when I started. My car was a test platform for a lot of materials. I followed forum "wisdom" at the time, applying layer after layer of various vibration dampers. Car was solid and all of those layers created a decent barrier but it was incredibly wasteful. Not to mention that the sheet metal is completely inaccessible so that even something as simple as PDR is impossible. Now that I've treated similar cars the proper way, I'm tearing out the old stuff to redo it. The proper amount of the right materials is easier, cleaner, less expensive and WORKS MUCH BETTER. Here's what I'm pulling out:That's right, 8 layers of mat followed by 2 layers of liquid. Terrible job.
