August 11, 201115 yr Author ran two runs each of power and ground, secured via zip strips and mostly inside of frame.not alot of pics, in fact only one was worth keeping....faila combination of 0 gauge american bass and welding cable....also will picking up two batteries from chicagofan this week end for the trunk.stinger spv70 Battery Specifications Cranking Amps: 1050 Watts: 2100 CCA: 875A Amp Hours: 70 Weight: 57.3 lbs Dimensions: 6-1/2"D x 13-3/4"W x 6-7/8"H fixed all the wiring in the dash, ready to install the alpine this weekend, with a little fitment tweaks and a new dash kit.little progress , but i am happy, feels like i am finally turning the corner!looks like i still have about 1 1/2" of lift left in the air shocks for the remaining weight ...so i should be fine with that too!
August 13, 201114 yr There are officially 2 like new Stinger SPV70's waiting on you at the house when you're back from visiting Alton NOW DO WORK SON!!
August 14, 201114 yr Author ordered some gear yesterday...should have .....(4x) 0 gauge, in line, anl fuse holders 20' 8 gauge blue speaker wire20' 8 gauge black speaker wire3 circuit breakers40 more 0 gauge ring terminals100' of 12 guage speaker wirenew dash kitblue digital volt meterthis should get me pretty close, i have a few other items chosen, just waiting on funds to get right...those batteries are top notch cosmetically bro, nice equipment, good seller = Chicagofan!
August 14, 201114 yr Author ready for this wall to be done lolneed to cut two more boards for the back and it will be duraglass time for a few days......then comes the sanding! lolweather just has not let up until now, but i am getting back in there!
August 14, 201114 yr Author more equipment I know, right!about time! lolmomma chop picked a AQ2200 for her durango today also, will be upgrading her ride soon too!
August 14, 201114 yr 40 ring terminals!? Sounds like you got your work cut out for you! Bring on the updates!!
August 14, 201114 yr Author 40 ring terminals!? Sounds like you got your work cut out for you! Bring on the updates!!lol, iak!measure, cut, strip, crimp, soder, heat shrink.........repeat ! lol
August 14, 201114 yr 40 ring terminals!? Sounds like you got your work cut out for you! Bring on the updates!!lol, iak!measure, cut, strip, crimp, soder, heat shrink.........repeat ! lolWith 40 to do I'm sure there will be more "repeats"!
August 14, 201114 yr Sweet ride. Unwanted foam leakage sucks, I feel you pain.Figure out the front stage plans?What's up with the icon pamphlets? Team SSA?
August 14, 201114 yr Author 40 ring terminals!? Sounds like you got your work cut out for you! Bring on the updates!!lol, iak!measure, cut, strip, crimp, soder, heat shrink.........repeat ! lolWith 40 to do I'm sure there will be more "repeats"!honestly bro, all 40 should not be used, but they are 10 packs, i always help out other local installs, so a few extra on hand is welcomed.the big three,(i always do 4), will be done in dual runs, so under the hood alone....block to frame ground = 4alt to frame ground = 4alt to battery positive = 4 battery to frame ground = 4battery negative going to rear = 2battery positive going to rear = 2 (the 4 in-line, anl fuse holders will not need ring terminals)there is 20 of those bad boys right there!then there is a trunk full too!coming out of the rear in-line, anl fuse holders going into the batteries positive = 2 battery 1 positive to battery 2 positive = 4coming out of battery positive into (3) circuit breakers = 6 *(3 amps)*coming out of circuit breaker going into amp positive = 3negatives coming from front battery into negative battery 1 =2battery 1 negative to battery2 negative =4 negative to amps from batteries = 3negative to chassis from batteries = 8 (preferance to be grounded in rear also still being pondered)thats 24 in the trunk .....i have 12 in the shed and 40 on the way... repeat*repeat*repeat* ................... lol
August 14, 201114 yr Author Sweet ride. Unwanted foam leakage sucks, I feel you pain.Figure out the front stage plans?What's up with the icon pamphlets? Team SSA?i am unofficially part of Team SSA....I rep them often on our local cruise strip and local shows.... for two years now, educating the masses! lolno, just informing folks of a sound alternative to some gear choices. i chose not to fully pursue the membership, until i have fully installed the Xcons.i have displayed the pamplet with three of the four SSA series subs for quite a while...Mark and Aaron know i am always representing them proudly.just on me to take the final steps.front stage, probably going to be in phases, as in trial and error basis.i think i am either tone def, or have picky taste,loli need loud, well i mean two 18" xcons behind my head, need loud enough to keep up nicely...i do not like harsh highs... and i love mid bass that can hit tight lil jabs to the kidneys and belch out vocals that tear right through the bass and still carry clarity......the doors and kicks are not truly 'ready' and waiting for custom upgrades....so here is my piss poor and hopelessly fail proof plan...start with equipment i can get close to what i think i like, slowly modding the areas needed to accomidate accordingly.....i think it will be a challenge for me to nail it the first few attempts, when i do, then i will fully coomit to the finished look.yes that means raw mdf and ruff glass projects for a short while, lolany input on acetone for foam leaks removal without harming the paint too much? jcthanks for the compliment!
August 14, 201114 yr Author If I have to count past 20, I'm out of fingers and toes!!lmao, iak brother....ha ha, the grandson has to help me out, he is the lil foreman on the job! gotta keep me on the right path.
August 14, 201114 yr It hurt to let those batts go but I know they'll be put to good use ........and the fact that they go to my lil brotha is what puts a smile on my face
August 14, 201114 yr As far as the foam on the paint, I would try to buff it out with a light cutting compound. You may need to re apply some clear coat then buff again.Based on your tastes a big 8"-12" midbass driver in each door along with a couple fullrange drivers (no dedicated tweeters) in the dash corners or a-pillars should make you happy
August 14, 201114 yr Boy bro, you got a lot of work ahead of you. If there's anything I might be able to do to help from all the way down here, just let me know! :drink40:
August 14, 201114 yr Lol man I think I used about 30 on my truck... But I have those bussbars and like 5 batts..Those terminals get used up quick!!Propane and solder lol
August 14, 201114 yr Author Lol man I think I used about 30 on my truck... But I have those bussbars and like 5 batts..Those terminals get used up quick!!Propane and solder lolthose buss bars are ftw!
