  • Replies 697
  • Views 81.1k
  • Sencheezy
    Sencheezy
    If you don't mind, I will post what I've been told.   Long story short. At one point and time, the vehicle was reported stolen. From what I've been told, this can date back to a total of four owners.
  • welcome to the gun show!!!!
I love that the car was caught by a magazine!!!! Just awesome bro!
  • 4 weeks later...
ran two runs each of power and ground, secured via zip strips and mostly inside of frame.
not alot of pics, in fact only one was worth keeping....fail
a combination of 0 gauge american bass and welding cable....
also will picking up two batteries from chicagofan this week end for the trunk.
stinger spv70
Battery Specifications
Cranking Amps: 1050
Watts: 2100
CCA: 875A
Amp Hours: 70
Weight: 57.3 lbs
Dimensions: 6-1/2"D x 13-3/4"W x 6-7/8"H
fixed all the wiring in the dash, ready to install the alpine this weekend, with a little fitment tweaks and a new dash kit.
little progress , but i am happy, feels like i am finally turning the corner!
looks like i still have about 1 1/2" of lift left in the air shocks for the remaining weight ...
so i should be fine with that too!
There are officially 2 like new Stinger SPV70's waiting on you at the house when you're back from visiting Alton NOW DO WORK SON!! :lol2::wub::woot::bigok::gift::rofl2::popcorn::drink40::dancing::morepower1:
ordered some gear yesterday...
should have .....
(4x) 0 gauge, in line, anl fuse holders
20' 8 gauge blue speaker wire
20' 8 gauge black speaker wire
3 circuit breakers
40 more 0 gauge ring terminals
100' of 12 guage speaker wire
new dash kit
blue digital volt meter
this should get me pretty close,
i have a few other items chosen, just waiting on funds to get right...
those batteries are top notch cosmetically bro, nice equipment, good seller = Chicagofan!
ready for this wall to be done lol
need to cut two more boards for the back and it will be duraglass time for a few days......then comes the sanding! lol
weather just has not let up until now, but i am getting back in there!
:woot: more equipment
I know, right!
about time! lol
momma chop picked a AQ2200 for her durango today also, will be upgrading her ride soon too!
40 ring terminals!? Sounds like you got your work cut out for you! Bring on the updates!!
lol, iak!
measure, cut, strip, crimp, soder, heat shrink.........repeat !
lol
lol, iak!
lol
With 40 to do I'm sure there will be more "repeats"!
Sweet ride. Unwanted foam leakage sucks, I feel you pain.
Figure out the front stage plans?
What's up with the icon pamphlets? Team SSA?
lol, iak!
lol
honestly bro, all 40 should not be used, but they are 10 packs, i always help out other local installs, so a few extra on hand is welcomed.
the big three,(i always do 4), will be done in dual runs,
so under the hood alone....
block to frame ground = 4
alt to frame ground = 4
alt to battery positive = 4
battery to frame ground = 4
battery negative going to rear = 2
battery positive going to rear = 2
(the 4 in-line, anl fuse holders will not need ring terminals)
there is 20 of those bad boys right there!
then there is a trunk full too!
coming out of the rear in-line, anl fuse holders going into the batteries positive = 2
battery 1 positive to battery 2 positive = 4
coming out of battery positive into (3) circuit breakers = 6 *(3 amps)*
coming out of circuit breaker going into amp positive = 3
negatives coming from front battery into negative battery 1 =2
battery 1 negative to battery2 negative =4
negative to amps from batteries = 3
negative to chassis from batteries = 8 (preferance to be grounded in rear also still being pondered)
thats 24 in the trunk .....
i have 12 in the shed and 40 on the way...
repeat*repeat*repeat* ................... :suicide-santa:
lol
If I have to count past 20, I'm out of fingers and toes!!
i am unofficially part of Team SSA....
I rep them often on our local cruise strip and local shows.... for two years now, educating the masses! lol
no, just informing folks of a sound alternative to some gear choices.
i chose not to fully pursue the membership, until i have fully installed the Xcons.
i have displayed the pamplet with three of the four SSA series subs for quite a while...
Mark and Aaron know i am always representing them proudly.
just on me to take the final steps.
front stage, probably going to be in phases, as in trial and error basis.
i think i am either tone def, or have picky taste,lol
i need loud, well i mean two 18" xcons behind my head, need loud enough to keep up nicely...
i do not like harsh highs... and i love mid bass that can hit tight lil jabs to the kidneys and belch out vocals that tear right through the bass and still carry clarity......
the doors and kicks are not truly 'ready' and waiting for custom upgrades....
so here is my piss poor and hopelessly fail proof plan...start with equipment i can get close to what i think i like, slowly modding the areas needed to accomidate accordingly.....
i think it will be a challenge for me to nail it the first few attempts, when i do, then i will fully coomit to the finished look.
yes that means raw mdf and ruff glass projects for a short while, lol
any input on acetone for foam leaks removal without harming the paint too much? jc
thanks for the compliment!
lmao, iak brother....ha ha, the grandson has to help me out, he is the lil foreman on the job!
gotta keep me on the right path.
MORE PICS !!!!
It hurt to let those batts go but I know they'll be put to good use :fing34: ........and the fact that they go to my lil brotha is what puts a smile on my face :drink40:
As far as the foam on the paint, I would try to buff it out with a light cutting compound. You may need to re apply some clear coat then buff again.
Based on your tastes a big 8"-12" midbass driver in each door along with a couple fullrange drivers (no dedicated tweeters) in the dash corners or a-pillars should make you happy :)
Boy bro, you got a lot of work ahead of you. If there's anything I might be able to do to help from all the way down here, just let me know!
:popcorn::drink40: :drink40::woot:
Lol man I think I used about 30 on my truck... But I have those bussbars and like 5 batts..
Those terminals get used up quick!!
Propane and solder lol
those buss bars are ftw!
