Posted October 28, 201015 yr Just a few vids of my recent install.. it's being pulled and redone this week.. but this is what it was Subs---4 Rival A12.22's Amps---2 Massive audio DB8000'sBatts---2 Odessey p2150sDeck---JVCPeak spl--152.6 @ 33hz... music or tone... doesn't matter Clamped power at peak SPL is 4250w, Redoing the box to redmy some of the box rise.. rising to 2.67ohm...<object width="480" height="385"><param name="movie" value="http://www.youtube.com/watch?v=SnZUPuYJ9hE?fs=1&hl=en_US&rel=0"></param><param'>http://www.youtube.com/watch?v=SnZUPuYJ9hE?fs=1&hl=en_US&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=SnZUPuYJ9hE?fs=1&hl=en_US&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object><object width="480" height="385"><param name="movie" value="http://www.youtube.com/watch?v=n-Mi8FmW0io?fs=1&hl=en_US&rel=0"></param><param'>http://www.youtube.com/watch?v=n-Mi8FmW0io?fs=1&hl=en_US&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=n-Mi8FmW0io?fs=1&hl=en_US&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object><object width="480" height="385"><param name="movie" value="http://www.youtube.com/watch?v=P13gcHL9dkU?fs=1&hl=en_US&rel=0"></param><param'>http://www.youtube.com/watch?v=P13gcHL9dkU?fs=1&hl=en_US&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=P13gcHL9dkU?fs=1&hl=en_US&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>**I can't get the vids to load right... if someone could help... lol
October 28, 201015 yr Author thanks Julian!now how do you get it to work? duran--the port isn't all that big... just 157.5" of area... the re-do I'm gonna stretch it out to 200in^2It's pretty violent right now... I need to get some better vids after the rebuild and more power
October 28, 201015 yr What do you consider a a not so bad ohm rise on your box below 2..because to me 2.67 isnt that bad of a ohm rise my box like's to go in the 5's.
October 28, 201015 yr Author Dictator-I just want the rise to be a little lower (I'd like to see it rising to MAYBE 1.8 from 1 that way when I wire down to .5 for burps I'll be sitting just below the 1ohm load needed to get these amps to really work well).. meaning I need the tuning to be a little closer to the peak freq. the box size will drop some which will aid in the lower rise as well**I guess I failed to mention... this box isn't even glued together.. just screwed--I knew I'd be making changes.. no bracing anywhere (just a big open box with a port slid in... the 1.5" thick does help keep it from flexing though..truck's getting four of the massive d8000 amps over the winter... and 10 Shuriken BT120 batts.. hopefully seeing 16k on a burp--and closer to a 156-157.... I'll keep working at this till I find a 60 or break the truck trying **hopefully the box re-do will net a nice little gain before the additional power...
October 28, 201015 yr Word that sounds good. If you could get it under 2.0 that be bad A**. Keep up on the build rush you have some sick skillz!
October 28, 201015 yr Click "insert media" (the last one next to "insert code snippet") then place the url into it.
October 29, 201015 yr Im still interested in these subs, cant wait till you get your production up and running. Nice videos and good scores.
October 30, 201015 yr Author Im still interested in these subs, cant wait till you get your production up and running. Nice videos and good scores.The subs are in production. i have more then plenty on hand. I just don't have the website up and running yet..
