I never said it wasn't going to be a great sub. Fs is much lower...
Fs won't play that big a part in the sub bass game either
So a sub with a 45 hz fs will play 20 hz just like a sub with a 30 hz fs?
  • Replies 81
  • Views 14.2k
  • ford302redneck
    ford302redneck
    Its amazing when people only look at two specs of a subwoofer and automatically assume one thing or another. I like the 1w/1m though. No BS rating FTW.
  • They weigh a lot more, handle a bit more power but for a 1000 watt rated driver a 3" coil does a better job.
  • It has to do with weight and mecanical limitations. A 4"coil takes up more of the spider and limets movement
In an anechoic environment, no, in an enclosure is a different story.
Do you listen to your music in an anechoic room?
Do you think he knows what a anechoic room is? :)
And the answer is no :P
You would be surprised what Sean knows.
Who do you think helps test and design subs with Jake?
Points. That guy.
In an enclosure, same story. A sub with a 45 hz Fs in a box tuned to 20 hz and playing 20 hz will sound like ass across the board. It will play it sure, but the frequency response will just be a gradual taper down to the playing frequency. If it were say, a 40 hz tune box, it would be relatively flat response till below tuning, where it would fall off quickly. There is a reason home theater drivers have a 15-20 hz Fs and similar tuning. Playing a full octave below Fs just won't have authority.
Would it blow your mind if I had one? :ohnoes9:
Apples to oranges ;)
No need to be a smart ass, I needed to clarify that looking at Fs alone should never rule out a woofer.
D4 specs with a very short break-in period :
Re : 7.00 ohms
Fs : 34.61 Hz
Qes : 0.57
Qms : 4.45
Qts : 0.51
Le : 5.05 mH
Vas : 17.39 L
BL : 29.23 NA
Mms : 324 g
Cms : 65.1 uM/N
SPL : 82.7 dB 1w/1m
Xmax : 19.0mm one-way
Bl^2/Re : 122
With break-in the Fs and Qts will drop a bit as well.
D2 specs with a very short break-in period :
Re : 3.94 ohms
Fs : 34.62 Hz
Qes : 0.52
Qms : 4.34
Qts : 0.46
Le : 3.57 mH
Vas : 17.16 L
BL : 23.28 NA
Mms : 328.7 g
Cms : 64.27 uM/N
SPL : 83.11 dB 1w/1m
Bl^2/Re : 138
IB install with one of these would be mighty interesting
