Posted December 6, 201014 yr will my saz-1000d xcon be ok powering my xcon? and when i wire to 1oh do i just put the + and - into the B speaker side?
December 6, 201014 yr will my saz-1000d xcon be ok powering my xcon? and when i wire to 1oh do i just put the + and - into the B speaker side?yes that would be perfectly acceptable. As for wiring here:http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=22
December 6, 201014 yr VIDEOS!!! there arent very many of xcons, sooo you should make a couple lolnice equipment
December 6, 201014 yr Author i will get video if i ever get it working. ive been having a lot of issues installing in my tundra for some reason. lots of noise. never had this problem in my old chevrolet
December 6, 201014 yr oh well that's because you're now driving un-american!! i concur. but whats the problem?
December 6, 201014 yr Author well, took my factory deck out, bought a metra wiring harness that uses the factory amp for the speakers and installed a friends pioneer headunit and it had noise that came through. couple days later i get my old alpine headunit back (cda-9827) out of my old chevy and put it in. it still had the noise. i tried grounding the HU to the battery and it didnt get rid of it. i tried grounding the rca's and it went away untill you turn the volume to 1-5 where the music was low enough to still hear it. but after grounding the rca's, even with nothing plugged into the HU i still get noise from my speakers. Im guessing all my problems are from the factory amp, so im gonna try to get a wiring harness to bypass the amp and just use the HU to power my speakers until i get a new component set and amp.Also when i plug my sub amp rca's into the HU i get an even louder whine, its nasty. unplug the rca's and it goes away. ive tried 2 different sets of rca's and it doesnt change anything. so there may be a chance that the preouts on my HU are bad also.but yea, i wish i was back to driving a chevy but the tundra is nice
