  • 2 months later...
  • Replies 54
  • Views 16k
  • altoncustomtech
    altoncustomtech
    Some updates here. We changed the turbo charger on the #3 unit last September, I put some pics of this up to give everyone an idea of how big the turbos are that run these engines. Here's a shot of t
  • altoncustomtech
    altoncustomtech
    Got more pictures for you all.     These pictures here are of an old Allison Turbine engine and compressor at one of the other locations.  The engine is rated for 4,000HP and it just does have an auto
Here's some more pictures of the engine parts.  We had coolant leak into the oil in the engine.  Upon making some inspections we found where some coolant looked as though it had leaked around one of the engine liners and caused our issue.  This week we tore into the engine to repair the issue.  What we found was a crack in the liner where one of the O-Rings that seals it inside the block goes around it.  I got some pictures today of the piston and liner outside of the engine and I'll post a few up of the signs we found that showed us we had an issue with this particular liner (#5 cylinder) and then I'll get some pictures up of some other interesting stuff like the oil filter system for these engines and the 96 filters it holds inside the filter housing.
Here's the evidence we found of the coolant leak inside the engine a couple of weeks ago.  You can see the greenish-yellow staining around the bottom of the liner and rust on the bottom of the piston skirt.
Here's the old liner out of the engine block.  In the last couple of pictures you can make out the crack that was the source of our coolant leak issue.
Here's a few of the piston and connecting rod from out of the engine and the new liner behind it.
Here's some shots of the engine block where the liner came out of.  You'll notice just how nasty it got inside there around the liner thanks to that coolant leak.  Tomorrow one lucky member of our team will be climbing down inside, standing on the crank and cleaning all that mess up.  I'll try to get some pictures of that as well.
So there's some neat stuff not seen by the average person.  Let me know of there's any other aspect of the engines, plant, etc. you'd like to see.
Okay, as promised here's some more pictures.  Got one of the where the liner belongs in the block after it was all cleaned up.  A few of a co-worker, we'll call him Bill because that's his name, greasing the hole so it's ready for the liner to slide in nice and smooth.  Then I got some of the oil filter housing, without and with new filters inside.  The last two pictures are of one half of the connecting rod bearing that we also replaced while doing this.
Here's the block and Bill.
Here's some of the filter housing before and after filters were installed.
And here's the lower (cap side) half of the connecting rod bearing.
