Posted December 23, 201015 yr Ok, just bought a new car and my ported box does not fit. So I need to make a new one.I have a 2008 Civic SI coupe. What I am wondering is speaker/port placement. I am use to SUV's and sub up / port back.I have read with a trunk that sub back / port back is the way to go. Just asking to make sure before I buy the material and build this box.Also, I see that SA 12's are 1.5 to 2.0 for ported boxes. With 1.75 being on there spec sheet.I have 1250 watts to push 2 12's and was wondering. Would it be better to go 1.5 / 1.75 / or 2? And what hz would you recommend?Currently the box I have is 3.5 @ 32hz and sounds ok with JL 12w3's in it.I am playing 70% rap/bass cd and 30% rock/metal right now. Should I stay at 32 or would there be a better hz to shoot for?I plan on selling the JL 12's with ported box soon and buying the SA 12's. Going to make the box hopefully in the next couple weeks.
December 23, 201015 yr I tend to prefer a 35hz tuning. Optimum is 1.75^3ft but it will come down to the vehicle and install as to how it will sound in the end.
December 23, 201015 yr Author Ok, just bought a new car and my ported box does not fit. So I need to make a new one.I have a 2008 Civic SI coupe. What I am wondering is speaker/port placement. I am use to SUV's and sub up / port back.I have read with a trunk that sub back / port back is the way to go. Just asking to make sure before I buy the material and build this box.Also, I see that SA 12's are 1.5 to 2.0 for ported boxes. With 1.75 being on there spec sheet.I have 1250 watts to push 2 12's and was wondering. Would it be better to go 1.5 / 1.75 / or 2? And what hz would you recommend?Currently the box I have is 3.5 @ 32hz and sounds ok with JL 12w3's in it.I am playing 70% rap/bass cd and 30% rock/metal right now. Should I stay at 32 or would there be a better hz to shoot for?I plan on selling the JL 12's with ported box soon and buying the SA 12's. Going to make the box hopefully in the next couple weeks.I should add. I like LOTS of bass. I am not looking at winning any SPL contests. I want to feel/hear it. Right now the JL's can rattle my eyeballs a little at 800watts. With the SA's I will be able to go to 1ohm and get the amp to 1250. I know it is probably far fetched, but I want to get on the path of the hairtrick! lol....anyway. Thanks for any help!
December 23, 201015 yr i say 2 cubes per sub from experience. they like the bigger box and 33 hz IMO, this is from doing multiple installs with SA-12s
December 24, 201015 yr Author i say 2 cubes per sub from experience. they like the bigger box and 33 hz IMO, this is from doing multiple installs with SA-12sThanks for the info.Might I ask what the difference would be going from 3.5 to 4 cu ft? And also, what would I hear different moving from say 32hz to 33hz or maybe down to 30hz?I currently have a box 3.5 @ 32hz but need to rebuild it for a different vehicle.Does a bigger box need less power from the amp?Say I have 1250 watts on the 3.5 cu ft box. Would I hear an increased output taking that same amp to a larger box?
December 24, 201015 yr i say 2 cubes per sub from experience. they like the bigger box and 33 hz IMO, this is from doing multiple installs with SA-12sThanks for the info.Might I ask what the difference would be going from 3.5 to 4 cu ft? And also, what would I hear different moving from say 32hz to 33hz or maybe down to 30hz?I currently have a box 3.5 @ 32hz but need to rebuild it for a different vehicle.Does a bigger box need less power from the amp?Say I have 1250 watts on the 3.5 cu ft box. Would I hear an increased output taking that same amp to a larger box?Nothing audible to your ear!
December 24, 201015 yr Author i say 2 cubes per sub from experience. they like the bigger box and 33 hz IMO, this is from doing multiple installs with SA-12sThanks for the info.Might I ask what the difference would be going from 3.5 to 4 cu ft? And also, what would I hear different moving from say 32hz to 33hz or maybe down to 30hz?I currently have a box 3.5 @ 32hz but need to rebuild it for a different vehicle.Does a bigger box need less power from the amp?Say I have 1250 watts on the 3.5 cu ft box. Would I hear an increased output taking that same amp to a larger box?Nothing audible to your ear!Ok if I cant hear it, I assume I would feel it? How much difference would it be...
