OK, Well I have tried a few things and nothing worked. But first I will tell you my situation. I have a 92 Ford Ranger xlt and a FI BL 15 in THIS Box with a Pyle Audio 2200 amp. My problem is that When the box and sub are in the cab of my truck and the head unit is off or on it doesn't matter. I receive a very loud buzzing sound when I turn the key on. Here is a video below to explain what happened.
http://www.youtube.com/watch?v=4JuZPgoYyYk
Please help me as much as you guys can.
Ok, Well I decided to drill a hole and ground to the frame and now the noise stop when ever the head unite is on but when ever you tap the metal it reverbs out the speaker? Also when the Head unit is off it makes the same buzzing sound. Could this be because my amp is not the best?
Sounds like it may be a problem on the rca inputs. Are the jacks all the way in? Do they make any kind of noise when you move them around?
That's a possibility. I had spliced them to make them shorter.
Lol..
I'd say buy a new pair off of Knu koncepts, that probably is the reason why :)
Definitely check your RCA's with a DVM.
