Posted January 21, 201115 yr Realized that I don't have them on the site or anywhere easy to find at the moment -- so here we go :D2 Model :RE: 3.28 ohms (series)FS: 41.6 HzQes: 0.513Qms: 6.606Qts: 0.476Le: 2.778 mHVas: 3.285 LBL: 17.138 N/ACms: 83.341 um/NMms: 175.654 gSens: 78.476 dB @ 1w/1mBL^2/RE: 89.5D4 Model :RE: 6.08 ohmsFs: 44.66 HzQes: 0.594Qms: 6.337Qts: 0.545Le: 4.26 mHVAS: 4.44 LBL: 21.20 N/ACms: 80.8 uM/NMms: 157 gSens: 80.06 @ 1w/1mBL^2/RE: 73.92
January 28, 201115 yr sxundownz, im interested in these as im buying two 8's with taxes, how much will one or two of these realistically take.
January 28, 201115 yr sxundownz, im interested in these as im buying two 8's with taxes, how much will one or two of these realistically take.It depends on box size. Look around the sundown forum and you'll find a thread with a gudeline to power handling vs box size.
May 2, 201114 yr Only specs I didn't see listed here that would be of further benefit is the SD and the XMAX.
August 28, 201114 yr Only specs I didn't see listed here that would be of further benefit is the SD and the XMAX.hey bro, did you find these specs?i am interested in the 4th order for her durango, but need to run a few numbers to determine if it can happen in this space...i have it saved somewhere how i wass told to sd if needed...but it easy enough if it already posted, lol
July 13, 201213 yr is finding sd and finding cone area suppose to be two different numbers?Cone area is SD. Some drivers differ because of different surrounds. Meaning one eight could have more or less than a different eight. At least that is my understanding.
July 14, 201213 yr You are correct, the width of the surround affects Sd. Sd is also affected by how the cone area was actually measured. Some companies use 1/2 the surround, others use 1/3 of the surround. So you could send the same driver to two different people and potentially get two different Sd figures, depending on which method each used.
July 15, 201213 yr You are correct, the width of the surround affects Sd.Sd is also affected by how the cone area was actually measured. Some companies use 1/2 the surround, others use 1/3 of the surround. So you could send the same driver to two different people and potentially get two different Sd figures, depending on which method each used.I measure the whole surround and then subtract 2/3 of it.
