Posted February 6, 201115 yr i got a khaotic enclosure and i was going to put it in my trunk, but it wouldnt fit, so now im putting it in the back passenger side seat. the box is vertical with the port above the front passenger's head rest. i took the passenger rear seat out, and im putting a wood barrier where the seat back used to be. not sure what kind of wood to use tho. then im mounting my 4 channel amp to the back of the wood barrier. was going to put MLVB on the barrier and then closed cell foam on top. then some more closed cell foam on the bottom of the seat where there is just metal now, so the box wont vibrate against it. so am i going the right way with this sound deadening? and also what would be the easiest way to secure the sub box so that it wont kill the person sitting in the front passenger seat?
February 9, 201115 yr was it a premade enclosure or did you have it custom made? measure twice, buy once brotha.
June 19, 201115 yr If it was a Khaotic enclosure, then it was probably premade. Do they even build custom fit boxes?
June 19, 201115 yr If it was a Khaotic enclosure, then it was probably premade. Do they even build custom fit boxes?This is like four months old haha. I hope he figured something out by now.
June 19, 201115 yr either that or he's in jail for allegedly killing his passenger with a khaotik enclosure...Doesn't sound good at this point.
June 19, 201115 yr LOL I have to figure out how to bolt my box down to my floor of my car as well, I have had to slam on the brakes a few times, and seen 350+ pounds of subs and box come flying towards me once or twice... SCARY ISH!
June 19, 201115 yr So.. where is the box at?lol.. ok.. well, you'd be mounting it where flat surfaces are.IF there are flat areas right under the box, look and see if you can access the flooring area under the car at those points..regardless of where it's at, you have to make sure you don't drill into something, you would be drilling out of the floor into nothing else.Use plenty of silicone to prevent rust and bolt\nut the enclosure down.
June 20, 201115 yr So.. where is the box at?lol.. ok.. well, you'd be mounting it where flat surfaces are.IF there are flat areas right under the box, look and see if you can access the flooring area under the car at those points..regardless of where it's at, you have to make sure you don't drill into something, you would be drilling out of the floor into nothing else.Use plenty of silicone to prevent rust and bolt\nut the enclosure down.^ lol ...you better get tints on that mofo thats just asking for trouble
August 24, 201115 yr Sweet. A box as big as the car! I like ur style. I got a two seater probe. I braced mine with scrap angle iron. And welded n bolted till solid.
August 24, 201115 yr Sweet. A box as big as the car! I like ur style. I got a two seater probe. I braced mine with scrap angle iron. And welded n bolted till solid.How is your first post on a thread months old LOL
September 26, 201115 yr Sweet. A box as big as the car! I like ur style. I got a two seater probe. I braced mine with scrap angle iron. And welded n bolted till solid.How is your first post on a thread months old LOL it was something new to add his idea! which i think is a great idea! hell for me I just used expanding foam and L brackets lol! (truck / car setup / 4 door car)
September 26, 201115 yr either that or he's in jail for allegedly killing his passenger with a khaotik enclosure...Doesn't sound good at this point.LOL look at this guys name! CorpseGrinder! lol! maybe he did go to jail! lol
