March 20, 201115 yr That car is way to sexy for a stationwagon. Looks like I need to come down there and build you an alt bracket...
March 20, 201115 yr Author Haha thanks, there is literally no space for another alt tho. Ill post pics of the engine bay later
March 24, 201115 yr Author When I read your post J-road, I read it as "dual alt bracket", now I see you said just bracket lol. I was going to say... look at all the space for nothing You can barely see the case of the alt underneath everything.Stock bassIt's even amp'd!^Hope the xcons get louder then this. Looks like a good spot for my tiny batteryI'll be adding another d1200 on the other side, after I get the dc alt, and can afford it. Not much progress I know
March 24, 201115 yr Good luck getting an alt in there or doing the big 3 lol. I did the big 3 and it was quite painful, ratchet extensions are pretty much required to get the bolt off.
March 24, 201115 yr Author Oh I don't know, just some average one... I know your not suppose to mix battery brands, oh well...
March 24, 201115 yr Author Good luck getting an alt in there or doing the big 3 lol. I did the big 3 and it was quite painful, ratchet extensions are pretty much required to get the bolt off.I didn't have a problem adding some wire from the positive stud to battery, ground wires seemed fine.Oh and I'm not fucking with putting the alt in... The ac condenser needs to be moved, front tire taken off, and cv joint removed. I'm having the shop do it when they replace the timing belt and tensioner Keep up the good work!Thank you
March 24, 201115 yr I should be getting my batteries any day now, going to put the monster HC 3800 in the spare tire well. I needs to buy me a good agm charger Im thinking of getting a Ctek, what charger you using.
March 24, 201115 yr Author I should be getting my batteries any day now, going to put the monster HC 3800 in the spare tire well. I needs to buy me a good agm charger Im thinking of getting a Ctek, what charger you using.Nice, oh just some average charger that I found in the garage I'm sure it's not the best... It did have different charge modes tho, I just used the lower amperage and longer charge.
March 24, 201115 yr Both of our builds are moving like turtles, but yours seems to be moving a hare faster LOL.
March 24, 201115 yr Author Both of our builds are moving like turtles, but yours seems to be moving a hare faster LOL. Seriously Well see who gets their box first
March 24, 201115 yr Hi, I'm a spammer. I am not welcome here so the mod staff edited my worthless post and banned me from posting again.
March 24, 201115 yr Author Maybe you are not a game lover. But you must know the game Buy WoW Gold. Some people would choose to Buy World of Warcraft Gold online as a result of MapleStory Mesos price. Sparing some time to play game is a good way to relax yourself. If you are interested in the game, choose more Runescape Gold to make your role stronger.Ill keep that in mind...
March 29, 201115 yr Author hmmm?I had some tang band 6 1/2s just laying in my room, figured I could try and make'm fit in my doors, if they suck I'll replace them with something else when I can afford it
March 29, 201115 yr Author I honestly don't know what I'm doing, just jumping in Going to add a couple more layers tonight, let it dry, tomorrow try and do some bondo / sanding
March 29, 201115 yr You need a respirator with a charcoal filter. The dust mask is doing nothing for you.
March 29, 201115 yr Author Nice job on the fiberglassing, I'm excited to see how they turn out.Me too! I'm hoping after I get a couple more layers, sand it, bondo, and wrapped in vinyl / pleather that it looks somewhat decent You need a respirator with a charcoal filter. The dust mask is doing nothing for you.Well then I'll take it off so I don't look like a fool, and go buy a respirator, thanks
March 30, 201115 yr Author Pulled off door panel, did another layer of resin and mat. Tomorrow lots of sanding and bondo!
March 30, 201115 yr Author Looking forward to how these will turn out. How are you mounting them?Not hundred percent sure, I know I can do screws from behind the door panels into the speaker baffle area. As for the left side where it's fb and no wood, perhaps lay down some two part epoxy?Any tips? I'm going to see how well this one fits on the panel, if it's close I'll finish it up, if not I may just make a new baffle and start over again
March 30, 201115 yr Looking forward to how these will turn out. How are you mounting them?Not hundred percent sure, I know I can do screws from behind the door panels into the speaker baffle area. As for the left side where it's fb and no wood, perhaps lay down some two part epoxy?Any tips? I'm going to see how well this one fits on the panel, if it's close I'll finish it up, if not I may just make a new baffle and start over againIf you are able to reach down into the pod, possibly nut&bolt to panel with a large washer on each side?
