Posted February 28, 201115 yr I have a 15in fi q that I love but i want more bass. Im running 1500 rms and i dont want to change my amp just my subs. Im looking at the sundown sa 12. I would be getting a pair and making another custom ported box. Ya or Nay?
February 28, 201115 yr I think the two SA-12's would have more output.Could you post the specs of the box for your Q and your planned box?
February 28, 201115 yr Author I think the two SA-12's would have more output.Could you post the specs of the box for your Q and your planned box?I dont remember the exact specs but 4 cubic inch box with a 4 inch aero port, tuned to about 33 hz. The new box i would have to plan out im still deciding if I want to upgrade or not and deciding if I got the money lol.
February 28, 201115 yr I wouldn't do that box, port is to small. But I think the 2 12"s would be better.
February 28, 201115 yr Author I wouldn't do that box, port is to small. But I think the 2 12"s would be better.Well haha I did that box and it is to small but its what I had available unfortunatly. But I think ill get those sundowns and build a nicer vented box and maybe a better am down the line.Thanks for your input! Keep it comin you might change my mind.
February 28, 201115 yr the 2 SA-12s should give you a nice gain in output over the single 15" Q in the right enclosure
March 24, 201115 yr two sa-12's would give you more output and sound good at the same time if you build the box right.
March 25, 201115 yr Admin The first question that should have been asked, was 'What enclosure is the Q in right now?'Rebuilding is always cheaper then buying new equipment.
March 25, 201115 yr The first question that should have been asked, was 'What enclosure is the Q in right now?'Rebuilding is always cheaper then buying new equipment.X2 and, what do you not like about it that makes you want to change.My first preference would be the one I can have the optimal box for. If your Q isn't already in one then I would suggest getting it there first.
