Posted March 1, 201115 yr how would this box work with 2 SA 12s in my tacoma on a blow through... i listen to rap and rocktuned to 31. 2 cubes per sub net... roughly... gonna be running a hifonics 2000d to them.
March 2, 201115 yr I would do subs on one side, port on the other. thats how i did mine, single nightshade does over 150 easy.Oh, and flared ports. They really help.
March 2, 201115 yr I dont see the placement of the subs and port as a problem. And do you mean internal flared or external? Either way it should do pretty well. GL with the build.
March 3, 201115 yr I dont see the placement of the subs and port as a problem. And do you mean internal flared or external? Either way it should do pretty well. GL with the build.It will do better if he ever decided to take it to a comp. I externally flared mine, helps with spl, and so i can change tuning easily.I also have a movable back on mine, so i can change the volume. works out great.
August 6, 20178 yr 8 hours ago, Richard Stevens said: Good 8 hours ago, Richard Stevens said: Box spl 8 hours ago, Richard Stevens said: Box spl WTF?
