Posted March 17, 201114 yr how long does it take for the btl to break in?ive heard the subwoofer break in is a myth
March 17, 201114 yr I am breaking in my N2 BTL 18, on about 1700-2000 watts maybe a bit less for about a month or less, Usually it takes 15 hours to break it in. MY gains on the amp are turned down, after a month im going to turn the gains up, Im not going to play 3K into it daily, although it can handle that. Edited March 17, 201114 yr by reelfish92
March 18, 201114 yr when i got my BTL, i put it in, and beat on it right away, no harm done. I noticed within a few weeks it got deeper and a little lower sounding. I assume that was when it was fully broken in. Kinda irritates me for some reason when i see people do these crazy break in rituals with their subs. lol.
March 18, 201114 yr You don't need to break the driver in, it's not a car. However, the more you play it the suspension may loosen a little and play a little louder.
March 18, 201114 yr Drive it like you stole it is a great saying you should think of in relation to breaking a sub in. The suspension will loosen up some over time and youll gain alittle. Only way to kill a sub is simply to much power, clipping, and over excursion. Thats my oppinion
March 18, 201114 yr "breaking in" is the spiders and surround getting looser, which will increase the low end output a little. You can put it's RMS to it right out of the box (in the right enclosure), no need to give it 1/2 rms, then 3/4 then full or whatever the hell it is people do.
March 18, 201114 yr The idea that a subwoofer will "break in" is not a myth. The suspension will loosen, which will change the parameters. Since the change in parameters is proportional, generally it won't significantly affect the response. The idea that you need to dedicate a specific "break in period" before using a driver is a myth. The driver will naturally break in over time with regular use. The idea that you need to use less power on a driver until it "breaks in" is also a myth. The only way to "break in" a driver is to actually exercise the suspension. Using low power levels would be counterproductive if your goal was to break in the driver.
March 18, 201114 yr If you guys really want to get into it, this guy broke it down play by play:http://www.audioholics.com/education/loudspeaker-basics/speaker-break-in-fact-or-fiction
March 18, 201114 yr Interesting topic for sure since I have only been playing mine for 6 days, thanks for sharing everybody above, I just need to what for clipping I have only found one song that clips (some Waka Flocka song-he sucks anyways)
March 25, 201114 yr There's no reason to play low power for a "break in period." Put the sub in your car and let it wang.
March 25, 201114 yr There's no reason to play low power for a "break in period." Put the sub in your car and let it wang.bite your lip and give it hell.
March 25, 201114 yr There's no reason to play low power for a "break in period." Put the sub in your car and let it wang.bite your lip and give it hell. That's what I tell my girl all the time.
