Posted March 19, 201114 yr too start off I'm not bashing any products this was just a direct swap.we started out with this box on a 40.1 @.5 did a 154.9then we dropped this inand only came up with this voltage drop was from 15.2 on the volt meter down to 13.4 on the 40.1and from 15.2 down to 12.3 on the 4500there was a nsb90 under the hood with 6 runs of wire to the back batteries they are 110lb data safes.the 40.1 was giving some crappy wave's on the TL and the sundown hard perfect wave's on every testwe are going to do the 4500 on 16 volts next and see what it will do thenhere is a pic of the wave with the 40.1 Edited March 19, 201114 yr by stevew007
March 20, 201114 yr o that is pretty cool to see! and I never really noticed the o-scope on the TL before lol! nice post! you don't have a clamp meter by any chances do you? so you will be able to find the output of each amp
March 20, 201114 yr Author o that is pretty cool to see! and I never really noticed the o-scope on the TL before lol! nice post! you don't have a clamp meter by any chances do you? so you will be able to find the output of each ampyeah there is a clamp meter but I always like to see DB gains instead of clamped power gains.but then again thats when i was doing street classes with 1 batt under the hood.friend of mine also brought up power compression and told me to add more port. so we will see what the future brings with the new vehicle
