July 14, 201115 yr Enclosure looks great, nice and stout. Can't imagine installing it though. Perhaps you could make a video for us to watch I plan on putting it in tonight...might get a vid
July 15, 201115 yr If not done so already I suggest attaching some wood to your back wall it will rattle and flex hella bad. I would hate to see you install that big ole box twice
July 15, 201115 yr Author If not done so already I suggest attaching some wood to your back wall it will rattle and flex hella bad. I would hate to see you install that big ole box twiceAlready taken care of
July 15, 201115 yr Author Doing the last of the resinBox is bolted in Edited July 15, 201115 yr by ilikedirt
July 15, 201115 yr That's going to be ridiculous. My exact thoughts Just nuts man, can't wait to see a video in a couple days.
July 15, 201115 yr Author Well, as far as the video of us putting the box in, theres not a video...I waited around 2 hours for my help to come, he never did. Then I was just like screw it, im doing this myself and I did! I just tilted the box on the side and got an edge propped on the false floor and slid it in...170lb box, couldn't believe it lolAt this rate....max 2 weeks for this to be jammin
July 15, 201115 yr Well, as far as the video of us putting the box in, theres not a video...I waited around 2 hours for my help to come, he never did. Then I was just like screw it, im doing this myself and I did! I just tilted the box on the side and got an edge propped on the false floor and slid it in...170lb box, couldn't believe it lolAt this rate....max 2 weeks for this to be jamminThat's impressive, this was mine:and there was no way I was able to lift it and set it in the rear, had to call a buddy over.
July 15, 201115 yr That's impressive, this was mine:and there was no way I was able to lift it and set it in the rear, had to call a buddy over.
July 15, 201115 yr With your enclosure, you mine as well wall it You could make a huge trim piece for it and seal everything behind it That's impressive, this was mine:and there was no way I was able to lift it and set it in the rear, had to call a buddy over. My friend rode his skateboard down the street and was like "shit...".
July 15, 201115 yr With your enclosure, you mine as well wall it You could make a huge trim piece for it and seal everything behind it From the title I assume he is walling it
July 15, 201115 yr Well, as far as the video of us putting the box in, theres not a video...I waited around 2 hours for my help to come, he never did. Then I was just like screw it, im doing this myself and I did! I just tilted the box on the side and got an edge propped on the false floor and slid it in...170lb box, couldn't believe it lolAt this rate....max 2 weeks for this to be jamminThat's impressive, this was mine:and there was no way I was able to lift it and set it in the rear, had to call a buddy over.How did you like this setup? Im thinking of doing the same thing with subs facing up and 3 aero ports facing back towards license plate just like this except with either 4 sa-10's or 2 12" bls
July 15, 201115 yr With your enclosure, you mine as well wall it You could make a huge trim piece for it and seal everything behind it From the title I assume he is walling it Yeah pretty much, I get carried away looking at pictures and not reading text. Although it's pretty much walled off
