Letting it break in won't make it anymore abuse tolerant.
  • Replies 329
  • Views 52.2k
  • basshead7890
    basshead7890
    finish up the new panel for the amps today, and i'm going to make a piece up cover up the gap i still have to repaint the port
  • basshead7890
    basshead7890
    i just finish painting coat of latex paint in port, im going to put another coat tomorrow and i still have to try to get that wrinkle out of the rear deck cover and make a panel for the gap
  • basshead7890
    basshead7890
    now I just have to put everything back together
Got it playing and it blew 30 min later
That's horrible! You didn't go ham on it right off the bat did you?
Yep full tilt like did all my other subs. Never had a problem before.
I personally would not go balls out until at least a couple hours play time to loosen the suspension a bit. Out of curiosity though where was the failure at?
I think the coil unraveled, when I press down on the cone it barely moves and I can hear scratching. My other coil was still working when I reconed it. Only reason I recone it was because when I bought it the cap was lose and I put goop and the original glue on different places on the cap coming loose so I put more goop on it till it just became an eye sore.
Seriously? Ok, everything i've heard about stiff spiders not allowing full xmax which entails less coil travel which builds up heat which unravels coils is all wrong. Sure it might not be by much, but I've seen a frequency response drop from 37 to 33 hz after a breakin period ( sure there are other factors since the enclosure was tuned @ 31hz and cabin gain and all). It doesn't take long as a few weeks, but I still wouldn't go full throttle on a brand spanking new recone.
I can definitely understand why you would recone. You keep your ride clean. Sucky situation for sure. Hope you get it back up and going!
Looks like Zv3 parts. Tuned in.
Yeah I thought the same thing when I saw it, also the black ring(what ever you call it) on the former says Sundown Audio on it too.
triple joint ring or collar. Those are actually really good parts imo.
Nice progress man.
The recone I blew
Also I just picked this up
Edited by marq7890
Been thinking about grabbing a 15" XSV2, sub looks beautiful. :fing34:
  • 2 weeks later...
How is it? Looks sweet!
I like it, to me it sounds better and easier to mount
Hell yeah. nice. Any difference on the meter?
I haven't got a chance to meter it yet
one of my Funkin' Audio RCA cables had a short in it when I got it, so I contacted DIYMA and they sent me 2 of there's for free
Edited by marq7890
Your install looks so clean man!!! Are you gonna paint the port? I'd do red
Damn that looks sweet!
Thanks and yea but I'm just going to stick with black
thanks
clean
  • 2 weeks later...
From Skar?
Yea
Sorry that happened, that's awful packaging. But typical.
I traded my 1500s for these
This is how they were shipped
WTF??!! FTL!!!
