photobucket isn't showing some of my pics so i used imageshack
the rear deck scraped when i was pushing the box in
  • Replies 329
  • Views 53k
  • basshead7890
    basshead7890
    finish up the new panel for the amps today, and i'm going to make a piece up cover up the gap i still have to repaint the port
  • basshead7890
    basshead7890
    i just finish painting coat of latex paint in port, im going to put another coat tomorrow and i still have to try to get that wrinkle out of the rear deck cover and make a panel for the gap
  • basshead7890
    basshead7890
    now I just have to put everything back together
Did a little work today, and I had a real bad rattle and I finally realized it was inside of my box, so im guessing one of my braces broke, so tomorrow im going to pull it out and redo it.
Also I'm thinking about carpeting everything with black carpet later too.
I took out the vertical dowel rods and just replace them with this, and it sounds much better.
sucks about the brace breaking... but atleast u fixed it and it sounds good :D
Sub looks huge! Should throw some more bracing in there, closer to the middle of the panels.
I like your fuse holder :)
Looks as though you have changed things around, but wanted to say nice work on the amp install!!!
Thanks for all the picks!!!
  • 2 weeks later...
:phatyo:
Looks tits
looks good
lookin good
made me a battery holder but i had to assemble it inside the trunk, I wish i thought to do it before I put my box in
i was able to get my rear speakers to fit too
Edited by marq7890
Nice. Sealed off that trunk nicely. I may be doing the same in another trunk car soon.. hope I can get mine as clean as yours. Good work.
  • 3 weeks later...
2 more pics with a better camera, also im going to put another coat of paint in the port
That looks very good!
omg that looks amazing!
  • 3 weeks later...
the vertical brace came loose again and started to rattle really bad so i just took it out, until I come up with a better way to brace.
aslo i am having alternator problems so i put my stock one back on but i still have the same problem just not as much. It seems that my alternator just quits and shut off at random times.
I went to a local car show today at The Speakerbox and they had a DB contest. They had 2 class, less than 3000 watts and over 3000 watts, I came in third in the less than 3000 watts.
this was my highest and it was on music playing dj monsta bass dropwith driver's door open. the mic was meca style at the headrest.
Edited by marq7890
get some metal threaded rods to brace...
i love the way u seal off the trunk very nice!!!
and nice job on getting 3rd :)
  • 1 month later...
Went to a comp today and place 2nd in AS3 and got phat install.
@37hz with my car off and passenger side door open playing lil wayne thats all i have
Edited by marq7890
  • 4 weeks later...
I bought some 1awg wire on sale from wireandsupply for a ground from front to back. it's kinda heavy and stiff too. I can definitely feel the difference between pure copper and cca weight.
Edited by marq7890
  • 3 weeks later...
I got some 1/0 welding wire from a local welding supply store to replace the cadence wire for my battery in the back
next im going to redo the cover for the amps, repaint the port, and rear deck
Edited by marq7890
  • 2 weeks later...
  • Popular Post
Nice install. I love it, I love it, I love it!!!
