January 29, 201214 yr Author photobucket isn't showing some of my pics so i used imageshackthe rear deck scraped when i was pushing the box in
February 5, 201214 yr Author Did a little work today, and I had a real bad rattle and I finally realized it was inside of my box, so im guessing one of my braces broke, so tomorrow im going to pull it out and redo it. Also I'm thinking about carpeting everything with black carpet later too.
February 5, 201214 yr Author I took out the vertical dowel rods and just replace them with this, and it sounds much better.
February 6, 201214 yr Sub looks huge! Should throw some more bracing in there, closer to the middle of the panels. I like your fuse holder
February 6, 201214 yr Looks as though you have changed things around, but wanted to say nice work on the amp install!!!Thanks for all the picks!!!
February 20, 201214 yr Author made me a battery holder but i had to assemble it inside the trunk, I wish i thought to do it before I put my box ini was able to get my rear speakers to fit too Edited February 20, 201214 yr by marq7890
February 20, 201214 yr Nice. Sealed off that trunk nicely. I may be doing the same in another trunk car soon.. hope I can get mine as clean as yours. Good work.
March 11, 201214 yr Author 2 more pics with a better camera, also im going to put another coat of paint in the port
March 31, 201213 yr Author the vertical brace came loose again and started to rattle really bad so i just took it out, until I come up with a better way to brace.aslo i am having alternator problems so i put my stock one back on but i still have the same problem just not as much. It seems that my alternator just quits and shut off at random times.I went to a local car show today at The Speakerbox and they had a DB contest. They had 2 class, less than 3000 watts and over 3000 watts, I came in third in the less than 3000 watts.this was my highest and it was on music playing dj monsta bass dropwith driver's door open. the mic was meca style at the headrest. Edited March 31, 201213 yr by marq7890
April 1, 201213 yr get some metal threaded rods to brace...i love the way u seal off the trunk very nice!!!and nice job on getting 3rd
May 6, 201213 yr Author Went to a comp today and place 2nd in AS3 and got phat install.@37hz with my car off and passenger side door open playing lil wayne thats all i have Edited May 6, 201213 yr by marq7890
June 2, 201213 yr Author I bought some 1awg wire on sale from wireandsupply for a ground from front to back. it's kinda heavy and stiff too. I can definitely feel the difference between pure copper and cca weight. Edited June 2, 201213 yr by marq7890
June 18, 201213 yr Author I got some 1/0 welding wire from a local welding supply store to replace the cadence wire for my battery in the backnext im going to redo the cover for the amps, repaint the port, and rear deck Edited June 18, 201213 yr by marq7890
June 28, 201213 yr Author Popular Post finish up the new panel for the amps today, and i'm going to make a piece up cover up the gap i still have to repaint the port
