Posted August 10, 201114 yr My Amp is Flickering back and forth out of protect and power..Ive changed the fuses..I have changed the power wire connenction and all...I'm outta Suggestions..Need Help Bad
August 10, 201114 yr okay well first tell us this:1. what amp2. what your cars electrical consists of3. how was your gain set4. what is your crossovers set at5. what is the rest of the amp settings while we are on the topic6. what is your ohm load7. have you check your sub to see if something messed up there8. what is your sub9. what is your name10. who is your daddy and what does he do lol! jkand report back and always try to give all the info you can right off the top!
August 10, 201114 yr i've seen rapid in and out protection caused from internal fault at rca inputs.Thing to try to rule that possibility out quick-Unplug all rcas and see what happens.If it stays on, start by plugging one in at a time until you find culprit.At that time, take that rca cable and plug it into another input channel on amp to rule out cable and preout channel from HU.Also.. when i have seen this happen in person.. the amp caught on fire about 10sec later... So hopefully it hasn't on you...
August 10, 201114 yr Author Lol at the last one..I'm Running a AP-1500 Electrical consists of stock ish..I turned the gain down on the amp yesterday when it first started doing that..Everything else one the amp is turned down..1ohm Load...Subs are fine..Subs are AQ HDC 15s..My Name is ???
August 10, 201114 yr Author i've seen rapid in and out protection caused from internal fault at rca inputs.Thing to try to rule that possibility out quick-Unplug all rcas and see what happens.I've unplugged the RCAs and it continues and thank god My amp hasn't caught on fireIf it stays on, start by plugging one in at a time until you find culprit.At that time, take that rca cable and plug it into another input channel on amp to rule out cable and preout channel from HU.Also.. when i have seen this happen in person.. the amp caught on fire about 10sec later... So hopefully it hasn't on you...
August 10, 201114 yr Author i've seen rapid in and out protection caused from internal fault at rca inputs.Thing to try to rule that possibility out quick-Unplug all rcas and see what happensIf it stays on, start by plugging one in at a time until you find culprit.At that time, take that rca cable and plug it into another input channel on amp to rule out cable and preout channel from HU.Also.. when i have seen this happenperson.. the amp caught on fire about 10sec later... So hopefully it hasn't on you...sorry I fd that Last Reply up..I unplugged the RCAs and it continues to do it
August 13, 201114 yr Your running an audiopipe amp? If I'm not mistaken that is made by maxsonix right? same as hifonics? Because when I first got my hifonics installed all it did was flash protect and barely powered my sub, so I had to send it back because the internals were f'd. Got a new one installed with the same wire and everything and it worked perfect, and still powers my sub great and hasnt happened once. They are not the best amps but good for a budget.
August 13, 201114 yr Your running an audiopipe amp? If I'm not mistaken that is made by maxsonix right? same as hifonics? Because when I first got my hifonics installed all it did was flash protect and barely powered my sub, so I had to send it back because the internals were f'd. Got a new one installed with the same wire and everything and it worked perfect, and still powers my sub great and hasnt happened once. They are not the best amps but good for a budget.Audiopipe is Audiopipe. No Maxxsonics involved at all.
August 13, 201114 yr Yeah my mistake I guess I got it mixed up with autotek, but if the amp has never worked I would think its the same problem.
