Posted September 6, 201114 yr Just looking to find out since I cannot easily see it posted already anywhere... If I get (2) SAX-1200Ds and link them together, what kind of output would I be looking at?? Mainly looking to find out if it is 2ohm stable if linked as well.. Thanks for any help fellas..
September 6, 201114 yr Author forget it... found it on woofersetc... hopefully that is right... Does this look right to everybody???Features:Digital Class-D Linkable Mono Block AmplifierDouble Sided Through Hole Epoxy PCB1 Ohm StabilityEfficiency : 86% @ 4 ohm, at 100Hz24dB/Oct Variable CrossoverMulti-Way Protection Circuitry (Thermal/Over Current/Speaker Short/Speaker DC Protection)RCA Line Input and Master Output24dB Octave Crossover SlopeVariable Subsonic FilterVariable Bass BoostVariable Low Pass FilterVariable Phase ShiftFour(4) Gauge Power Supply ConnectorsTested Voltage & THD : 14.4V & Less than 1% THDOperating Voltage : DC 10V~16VWired Remote Controller Specifications:Rated power output RMS power, 2 ohm linkable/dual mono2160W x 1CHRMS power, 1 ohm mono1200W x 1CHRMS power, 2 ohm mono720W x 1CHRMS power, 4 ohm mono360W x 1CHSignal to Noise Ratio >90dBLow pass frequency crossover 35Hz~300HzSubsonic filter 10Hz~60HzBass boost @ 45Hz 0~6dBPhase shift control 0~180 degreeFrequency response 10Hz~350Hz (+/- 1dB)T.H.D @ 4 ohm <0.1%Efficiency @ 4 ohm 86%Fuse rating 40A x 3Input Sensitivity 200mV to 6V (+/- 5%)Dimensions 252(W) x 58(H) x 310(L)mm SAX1200D - Sundown Audio 1200W 1-Channel Monoblock Amplifier SAX 1200D
September 6, 201114 yr From what I've read on forums you're fine as long as they are the same version, you can't have one v1 and another v2. Might want somebody elses opinion as well though.
September 6, 201114 yr Author Cool, I just found the manual stating the output I found was correct... But I'm just curious about the gain? I remember reading through a thread stating that only the master gain had to be set and crossover settings as well.... Thanks for finding that one. :fing34:
September 6, 201114 yr Author Should I be doing this or go for like an ap1800.1??? I'm needing more output.. other option is to go ported...
September 6, 201114 yr Author lol... I ain't made of money Sean, unless you helping me with the ported enclosure...
September 6, 201114 yr lol... I ain't made of money Sean, unless you helping me with the ported enclosure... I would spend the money to go ported first and then get the amplifier/s. If the two 1200s is a great deal then jump on it.
September 6, 201114 yr Author Okay, I guess I need to look at getting some design drawn up by somebody... I can figure dimensions with Torres' calculator but I don't think I could "design" the whole thing...
September 6, 201114 yr Just have Audibel Customs build one for you. The "affordable" ones look very nice and are priced right.
September 6, 201114 yr Author Just have Audibel Customs build one for you. The "affordable" ones look very nice and are priced right.Can't do his affordable enclosure... After displacement it would leave me with less than 3 cubes which is not something I think would be a good idea.... SSA recommends 3+ cubes..
September 6, 201114 yr Well with the extra wattage you could probly go with a smaller enclosure... right?
September 6, 201114 yr i wouldnt want to go under 3 cubes though, if thats the minimum recommended size
September 7, 201114 yr lol... I ain't made of money Sean, unless you helping me with the ported enclosure... I would spend the money to go ported first and then get the amplifier/s. If the two 1200s is a great deal then jump on it.Definitely. Start by making your xcon efficient with the power you have.
