Posted September 15, 201115 yr Some pics of a few pallets of our Z v.3 motors at the factory before magnet boots are put on :* Similar style cap to newest SA series.* Large rear flare applied like newest SA series.
September 15, 201115 yr Author As they were just loaded up this week we are expecting them in ~30 days.I am not planning to do any pre-ordering as we are backed up enough on built products as-is but they will be available soon
September 15, 201115 yr Looks similar to the RD Heavyweight motor? Or is it the SuperHW? Anyways, this looks alot better/meaner. Looking foward to how the whole sub turns out.
September 16, 201115 yr Looks similar to the RD Heavyweight motor? Or is it the SuperHW? Anyways, this looks alot better/meaner. Looking foward to how the whole sub turns out.Looks are superficial! RD couldn't design a proper toothpick!
September 19, 201115 yr Do you have a thread about the specs of these? How will 2 18's take a 16 cube wall? Will it drop their power handling capabilities? 1500wrms?
September 19, 201115 yr Author With the 18s you have a huge 9.25" spider so they'll handle some juice.We rate them 1500 RMS conservatively.
September 20, 201115 yr Are there any other concerns with running them in that size enclosure? They will run 489 for the 18's correct?
September 30, 201115 yr Author Are there any other concerns with running them in that size enclosure? They will run 489 for the 18's correct?On 1500 RMS I wouldn't be worried about them -- the 18s will be 480, yes.It takes pretty big power to max out the 9.25" spider even free air.
October 2, 201115 yr So the 3500D should be a perfect match for 2 12's?Should be, I dont see why not.
