Posted September 20, 201115 yr I plan to get two SA 12s along with either a sax 1200 or saz 1500. I need some box dimensions and what one of those amps to get. I mainly play rap with a lot of lows if that helps.Thanks!Out of all the designs on here there are no dual 3.5^3 enclosures, and those don't list the frequency. Edited September 20, 201115 yr by djtomczak
September 21, 201115 yr Did you try looking at the box design section over on ROE. I think they have a bunch of designs over there. You could always ask for a design from one of the reputable box builders on the forums
September 21, 201115 yr Author Did you try looking at the box design section over on ROE. I think they have a bunch of designs over there. You could always ask for a design from one of the reputable box builders on the forumsNo dual 12s over there . I'll make a post in the builders forum.
September 24, 201115 yr Without knowing your vehicle or the dimensions it's hard to just spit out a box for you. However I can give you a general idea which is my box, 4cuft after displacement (3) 4" Aero ports 12" length. Here's a video of the box doing work on my windshield, and the 2 sa12s run off a SAZ1500D at 1ohm mono.
September 25, 201115 yr Welcome .... Yes I am new to the forums by the way haha.Welcome 1 more time!!!!
