Posted September 24, 201114 yr Hello Guys, I dont have any real pictures yet, but iv decided to get a little hype going for my first ever build. So heres what is going to be happening.Iv got a 2004 Impala, Currently with a set of Infinity 5.25 Reference components and Pioneer 6x9 coaxials in the back, powered by a PG Ti 500.4.. I had 2 Alpine Type X 10" and sold them.Now what will be happening with my current setup is as follows-Removing rear 6x9's to make room for my box in the trunk.-Replacing Infinity's with Bravox CS50k's-Keeping PG Ti 500.4 to power Bravox's-American Bass VLF 100.1 to power the subwoofer-18" Fi BTL N2 in the trunk, tuned to 32hz.Ill be building a box out of cardboard to make sure it will slide in nicely before i actually build the full thing. Pictures coming soon of my sub and amp, Ill also be posting the process of building my box (Be easy on me its my first time!)
September 24, 201114 yr Sounds like its gonna be a good build. My friend wants to fit an 18" into the same impala. Tuned in to see how this goes
September 24, 201114 yr I'm looking forward to seeing your build progress bro. Doing the build log on here is a great thing too. It won't be easy shoe horning that 18 into that trunk and I figure you're gonna need some help. What better place to get it? Well, bring on the pics, mach up box and all. This will be a great build if you take your time and do it right. Now,
September 24, 201114 yr Author Well... im at my girlfriends house tonight... and tomorrow is football.. So ill do my best to get those pictures in on Monday
September 29, 201114 yr Author Alright, got some pictures. Heres my Fi BTL N2 18", the AB 100.1 and what done of my box so far. Hopefully get a bit more done later tonight Edited September 29, 201114 yr by MikeMartel
September 30, 201114 yr Fuckin' yay! It's about time brother, you've got plenty to work with, I hope everything works out for you.
September 30, 201114 yr Author Feeling a bit better about it today, yesterday i was a little nervous because it was my first time but im getting the hang of it. Had a little bit of a scare because i split the wood with my first screw I used a bit of a bigger drill bit for my pilot hole and that fixed the problem. Hopefully pictures later tonight.
September 30, 201114 yr Author Here is what i got done last night.. Ill be putting up more pictures up on sunday, or maybe even tomorrow night when its done!
October 3, 201114 yr Author Ok... So my box wont fit with the double baffle.. Its too high. I think what ill do, is use the router to cut the height down just around where the sub needs to be mouted, that way i can still basically have a double baffle, with the same height as a single.
October 3, 201114 yr Ok... So my box wont fit with the double baffle.. Its too high. I think what ill do, is use the router to cut the height down just around where the sub needs to be mouted, that way i can still basically have a double baffle, with the same height as a single.Like flush mount?
October 3, 201114 yr I think that's what he means, and flush mounts are sexy, so no biggy! lolAlso- Are you building that enclosure in your living room?!
October 4, 201114 yr Author Building it in the basement, OK so, here is what iv decided to do, because it wont fit, and because i butchered that one baffle pretty bad this is what i did.I kind of flush mounted a bottom baffle for extra support, and will be screwing the top baffle to that. Heres what it looks like. (I know i know i messed up that cut bad, thats why its on the bottom )My box doesnt fit with the top on so its not secured yet.. Im going to have to slide my box into my trunk first, then glue and screw down the top baffle and sub while its in my trunk with like 2" clearance..... awesome Also, got my gains set properly using my multimeter and a 45hz test tone. What do you think . Not bad for my first time.
October 4, 201114 yr Building it in the basement, OK so, here is what iv decided to do, because it wont fit, and because i butchered that one baffle pretty bad this is what i did.I kind of flush mounted a bottom baffle for extra support, and will be screwing the top baffle to that. Heres what it looks like. (I know i know i messed up that cut bad, thats why its on the bottom )My box doesnt fit with the top on so its not secured yet.. Im going to have to slide my box into my trunk first, then glue and screw down the top baffle and sub while its in my trunk with like 2" clearance..... awesome Also, got my gains set properly using my multimeter and a 45hz test tone. What do you think . Not bad for my first time. This is the only way I do double baffles. I hate the way slot enclosures look with a 1.5" thick top at the port opening with a 3/4" side and bottom, call me crazy. Good job!!!It looks great dude, can't wait to hear your first thoughts on how it sounds and how loud it can play over your old 10's!!
October 4, 201114 yr Im kinda curious on how your gonna screw in the top baffle and get the sub in while its in the trunk? So far its a nice start.
October 4, 201114 yr Author Hehe, its a stunt let me tell you. Ill post step by step pictures of how i need to do it. Because theres so little clearance ill be using a ratchet with a star screwdriver attachment to crank down all the screws. BTW, does anyone have suggestions as to what screws i should use to actually mount the subwoofer with?
October 4, 201114 yr Lookin' good! Do you plan on removing the sub more than once or twice? If not, drywall screws will probably work just fine.
October 4, 201114 yr predrilll your holes for your sub screws other wire you will never get the screws in
October 4, 201114 yr Author Yep, i make sure i predrill all my holes. Im not risking splitting any more wood..
October 5, 201114 yr Author Alright, everything is in, and its leaking on the 'port side' outer wall, its at the back and was almost impossible to get screws into. I tried gluing it the best i could but theres a section in the center of it thats leaking. Because its in the port side im pretty lucky, later today ill use some silicone and put a bead on both the inside and outside seam and then hopefully everything will be ok.(Leaking side, put some wood glue for now, silicone later)And a few pictures of my amps. (Dont slam me for my cap i know its useless)
