Posted September 26, 201115 yr well yesterday i took all of my max dimensions and came up with 7.1cf. and thats before port and sub displacement.... so i have a few questions about this....1. will this box (after sub and port displacement) be big enough (doing 1 big single chamber) &2. what would be a good port width to go with? jaycee said tuning them @34hz would be a good start but im not sure on how wide to make the port. any thoughts????3. i was told that in a truck, having the subs and port both up gets the best results. is this true?im using 2 10" kicker solo x's Edited September 26, 201115 yr by Lantz
September 26, 201115 yr I never gave you box recommendations or a frequency to tune at, dont get me involved in your failure.
September 26, 201115 yr Author I never gave you box recommendations or a frequency to tune at, dont get me involved in your failure. my failure???? and i meant jay-C76
September 26, 201115 yr That's plenty of volume.Download Winisd if you don't have it, create a new driver profile, fill out all the T/S specs for your kickers.Make a new project, fill everything out, go to the ports tab, pick either square (slot port) and plug in some numbers for width and height, or use round for aero ports. The program will automatically calculate the port length required for the tuning you picked earlier.Also, you will be able to see the port/vent mach, try to have that number in green. The lower the number, the less port speed and turbulence you'll have, thus less port noise.
September 26, 201115 yr Author That's plenty of volume.Download Winisd if you don't have it, create a new driver profile, fill out all the T/S specs for your kickers.Make a new project, fill everything out, go to the ports tab, pick either square (slot port) and plug in some numbers for width and height, or use round for aero ports. The program will automatically calculate the port length required for the tuning you picked earlier.Also, you will be able to see the port/vent mach, try to have that number in green. The lower the number, the less port speed and turbulence you'll have, thus less port noise.i went on the12volt.com and they have the calculators set up to find port length and box volume. does this winisd cost money or how does it work? iv never heard of it before
September 27, 201115 yr That's plenty of volume.Download Winisd if you don't have it, create a new driver profile, fill out all the T/S specs for your kickers.Make a new project, fill everything out, go to the ports tab, pick either square (slot port) and plug in some numbers for width and height, or use round for aero ports. The program will automatically calculate the port length required for the tuning you picked earlier.Also, you will be able to see the port/vent mach, try to have that number in green. The lower the number, the less port speed and turbulence you'll have, thus less port noise.i went on the12volt.com and they have the calculators set up to find port length and box volume. does this winisd cost money or how does it work? iv never heard of it beforeFree and much better than just using the12volts calcs.
September 27, 201115 yr You could use the12volt, but how would you know you have enough port area?And how would you calculate port displacement for NET volume if the port length itself is dependent on the net volume?Just some food for thought.As Duran said, Winisd is free. Download, install. Look up T/S specs for your driver and plug it in. Read the article / how to / tutorial if you need help figuring it out.If you can't figure this out or don't want to spend the time to figure it out, contact someone that designs enclosures and pay them to do it. I've heard great reviews for Ram Designs.Either way, do it right, or don't do it at all.
September 27, 201115 yr Author You could use the12volt, but how would you know you have enough port area?And how would you calculate port displacement for NET volume if the port length itself is dependent on the net volume?Just some food for thought.As Duran said, Winisd is free. Download, install. Look up T/S specs for your driver and plug it in. Read the article / how to / tutorial if you need help figuring it out.If you can't figure this out or don't want to spend the time to figure it out, contact someone that designs enclosures and pay them to do it. I've heard great reviews for Ram Designs.Either way, do it right, or don't do it at all.you have a point sir. i will download it tomorrow and give it all a whirle
September 27, 201115 yr I never gave you box recommendations or a frequency to tune at, dont get me involved in your failure. my failure???? and i meant jay-C76 Hell Lantz, my bad, I thought you weren't gonna do this box build.I'll send ya the design before the weekend.Get Google SketchUp (it's free) so you can view the design.side note- cut Lantz a little slack guys. He's new to the game (compared to most of us)and is trying to "bass on a budget". He may ask some questions that to us may seem dumb.He's trying to learn, (the hard way sometimes) but all in all at least he asks question instead of assuming.
September 27, 201115 yr Author I never gave you box recommendations or a frequency to tune at, dont get me involved in your failure. my failure???? and i meant jay-C76 Hell Lantz, my bad, I thought you weren't gonna do this box build.I'll send ya the design before the weekend.Get Google SketchUp (it's free) so you can view the design.side note- cut Lantz a little slack guys. He's new to the game (compared to most of us)and is trying to "bass on a budget". He may ask some questions that to us may seem dumb.He's trying to learn, (the hard way sometimes) but all in all at least he asks question instead of assuming.thanks jay-c. i appreciate it. iv only been in the whole audio game for just over 2 years now. its my favorite hobby haha
September 27, 201115 yr You could use the12volt, but how would you know you have enough port area?And how would you calculate port displacement for NET volume if the port length itself is dependent on the net volume?Just some food for thought.As Duran said, Winisd is free. Download, install. Look up T/S specs for your driver and plug it in. Read the article / how to / tutorial if you need help figuring it out.If you can't figure this out or don't want to spend the time to figure it out, contact someone that designs enclosures and pay them to do it. I've heard great reviews for Ram Designs.Either way, do it right, or don't do it at all.Awfully elitist don't you think? Nobody EVER "does it right" on their first try.He's not dumb. Just eager and uneducated like we all started.
September 27, 201115 yr Author You could use the12volt, but how would you know you have enough port area?And how would you calculate port displacement for NET volume if the port length itself is dependent on the net volume?Just some food for thought.As Duran said, Winisd is free. Download, install. Look up T/S specs for your driver and plug it in. Read the article / how to / tutorial if you need help figuring it out.If you can't figure this out or don't want to spend the time to figure it out, contact someone that designs enclosures and pay them to do it. I've heard great reviews for Ram Designs.Either way, do it right, or don't do it at all.Awfully elitist don't you think? Nobody EVER "does it right" on their first try.He's not dumb. Just eager and uneducated like we all started.true. i want to start the build for the solo x's this week. im going to get a sheet mdf tomorrow. and hopefully one sheet will do the whole job.
September 28, 201115 yr You could use the12volt, but how would you know you have enough port area?And how would you calculate port displacement for NET volume if the port length itself is dependent on the net volume?Just some food for thought.As Duran said, Winisd is free. Download, install. Look up T/S specs for your driver and plug it in. Read the article / how to / tutorial if you need help figuring it out.If you can't figure this out or don't want to spend the time to figure it out, contact someone that designs enclosures and pay them to do it. I've heard great reviews for Ram Designs.Either way, do it right, or don't do it at all.Awfully elitist don't you think? Nobody EVER "does it right" on their first try.He's not dumb. Just eager and uneducated like we all started.I'm simply stating: don't slack when designing the enclosure, or spend the money and have someone do it correctly. I'm not being an Elitist...I apologize if I personally offended you. If you installed new speakers, you wouldn't just twist the wires together and wrap some electrical tape on it, would you? Spend an extra five minutes and solder everything.If you were designing a ported enclosure with a 35hz tune, but didn't bother to account for driver & port displacement, think you'd still be near your 35hz?I'm not being a dick, all I'm saying is: take your time and do it right the first time... or don't bother doing it yourself.
September 28, 201115 yr Author jay-C76: ya i just installed it. shes ready to go hahaStephan: you have a point. i see where your coming from... Edited September 28, 201115 yr by Lantz
September 28, 201115 yr jay-C76: ya i just installed it. shes ready to go hahaStephan: you have a point. i see where your coming from...I'm glad, because I'm not trying to steer you away or put you down in any way.
September 28, 201115 yr Author jay-C76: ya i just installed it. shes ready to go hahaStephan: you have a point. i see where your coming from...I'm glad, because I'm not trying to steer you away or put you down in any way. no your good. iv never built a box this big before so it will be quite an adventure for me.... haha
September 28, 201115 yr well jay-c76 designed my 2nd enclosure for the ASTRO and it IS AWESOMENESS! I am SO TUNED IN to see how this turns out! On a side note I feel if JAY-C76 designs an enclosure that potentially starts to shatter your window he should be held partially responsible... ILL be sending my SAFELITE repair SAFELITE replace bill with a <^> attached!
September 28, 201115 yr Author well jay-c76 designed my 2nd enclosure for the ASTRO and it IS AWESOMENESS! I am SO TUNED IN to see how this turns out! On a side note I feel if JAY-C76 designs an enclosure that potentially starts to shatter your window he should be held partially responsible... ILL be sending my SAFELITE repair SAFELITE replace bill with a <^> attached!haha. i cant wait to see how the design turns out.... p.s. i am going to make a new thread here shorty. i want to know the best way to make this box. like wood glue,sould i use screws or staples. that kind of stuff.. i need as much help as i can get!
September 28, 201115 yr well jay-c76 designed my 2nd enclosure for the ASTRO and it IS AWESOMENESS! I am SO TUNED IN to see how this turns out! On a side note I feel if JAY-C76 designs an enclosure that potentially starts to shatter your window he should be held partially responsible... ILL be sending my SAFELITE repair SAFELITE replace bill with a <^> attached!haha. i cant wait to see how the design turns out.... p.s. i am going to make a new thread here shorty. i want to know the best way to make this box. like wood glue,sould i use screws or staples. that kind of stuff.. i need as much help as i can get!use Elmers wood glue the blue label.....Use Screws for sure not staples..... and I would say fiberglass resin all the corners and let cure over night! and TAKE YOUR TIME!!!!!!!!!!!!!!!! DO NOT RUSH!!!!!!!!!!!!!!!
