Great work. Nice to see some details with this build. Always clean! :drink40:
  • Replies 50
  • Views 8.3k
  • I make all my RCA's. Blue for sub, yellow for front, green for rear Enclosure build for JL Audio 13W6 Minimal use of sound deadening tiles JL Audio XD600/1 mounted under driver's seat JL Aud
  • Stock sail panels 6.5's mounted with dual 0.75" mounting rings My MDF mounting rings are mechanically fastened to the stock metal door skin. I also used sound deadening material around the rings
  • Ground strip located near head unit that is routed directly to battery. This used for the HU, RA, relay and volt meter.
I've probably said it fifty times by now, but man everything you do is so clean. :drink40:
Thanks bro. I am going to drop an SQ bomb on the Hyundai next year!
What kind of camera do you have? Rally nice quality pictures.
For 90% of these shots I use a Nikon D7000 with AF-S DX NIKKOR 16-85mm f/3.5-5.6G ED VR lens and SB-800 flash with dome diffuser.
Thanks watts09.
Can't wait to see what you have in store. :)
I still have to open up my kick pods and see if my ex-anarchies open up any.
What do you mean open up? Are you going ported from sealed? When I was doing my Anarchy build they are way more efficient ported. If I remember correctly I was building for 0.5-0.7^3ft tuned to 60-70hz.
I remember reading from a couple users that the Anarchy mounted IB is very poor.
Trying to port my kicks would be a pain trying to get enough port length under the dash for around 70-80hz. Ill have to check specs and my math again heh.
I was planning on cutting open the back and making it almost ib / aperiodic, since it would be open against the carpet floor. I can always close them back up relatively easily.
Was the info on ib for the anarchies on diy ma?
Here is the review I was speaking of. Take it for what it is. I am the type that has to do it myself to really believe, I think you are too. It sounds like you are going for a "leaky sealed" approach? Maybe that will work well for your setup. Based on the driver QTS small ported or large sealed is best. But again, from what I read, IB did not do so well.
I could be wrong, but wouldn't very large sealed = ib?
Oh and modeling ib didn't look spectacular, but id still like to try it like you said.
An average "rule of thumb" is to determine if the volume of air behind the baffle equals or exceeds three times the Vas of driver. You would have to figure that out for the Anarchy. Just remember efficiency will suffer on an already low efficient driver, so will power handling. But we are talking upper bass region to midrange frequencies, might be a different ball game.
What the hecks, give it a try :P
Ported would be tits!
As posted above, Nice Work!! :drink40:
Very nice Bro.
Uber clean, always!
:drink40:
Thanks fellas! I am waiting to see pics of what both of you have been working on :peepwall:
  • Admin
Very nice work! :)
Very nice work! :)
:drink40:
Thanks fellas. Next year I am doing a SQ setup with my XCON 15" sealed. Maybe if my wife-to-be allows it (lmfao) I will compete :peepwall:
Very nice, clean work!
Thanks ricksi30
It's been said a lot, but very clean work. Looks great :)
:drink40:
  • 2 months later...
:drink40:
Beautiful work bro!!!!
J
:drink40:
J
Thanks fellas.
How did this get 1 star?? Install looks professional and the pictures kick ass. Gave you 5 stars for what it's worth. :shrug:
:ughdunno:
Thanks man
Nice work! very clean looking install :drink40:
can we stop telling him that it looks nice n clean (which it is ! ) and leave some more room for new pics ...
more pics, less chat !!
thanx
it really looks good though :popcorn:
