Posted November 7, 201113 yr ok guys i blew a coil outta my sa-15 today i was wondering if its possible to recone it to a sa-8 dumb question but i was just wonding the cost and stuff. thanks =me):
November 7, 201113 yr I believe the SA-8 is a 2" coil, where the larger cones use 2.5" coil I believe; not 100% sure.
November 7, 201113 yr I could be wrong but I think you could only build a 10, 12 or 15 with that motor.
November 7, 201113 yr I believe the SA-8 is a 2" coil, where the larger cones use 2.5" coil I believe; not 100% sure. I also think this is true. Plus this is also the case on the Skar models.
November 7, 201113 yr Author Correct. The 8s have a different motor with 2" coilbummmer): but thanks anyways i might recone to a ten then(:
