Wheres the BP option when buying the 12 SSD? Is it not offered any more?
It's now a solid pole, no BP to add.
BP was just the plug, cooling added the plug and cooling channels if I recall.
No
http://www.soundsolu...ecommendations/
BP Power - This option adds a machined aluminum compression plug to the pole which helps channel all of the air under the dustcap around the coil for better cooling. To aid with this increased airflow we also add 6 axial cooling channels in the top plate. Along with increased thermal capacity comes the addition of an extra spider and a changed spider pack. All of these features increase power handling from 200-500 Watts depending on the application.
I stand corrected, thanks Nate :)
Does the cooling option add any RMS to the sub?
