December 8, 201113 yr Author lmao its a 94 civic hatch but i got my other sa12 on the way and its gonna be 1500w
December 8, 201113 yr So you already have 1 sa-12 but you ordered a second and now asking which will be louder on 1500w? Well the answer is easy then, keep what you got and if it isn't loud ENOUGH then upgrade son!! lol
December 8, 201113 yr So you already have 1 sa-12 but you ordered a second and now asking which will be louder on 1500w? Well the answer is easy then, keep what you got and if it isn't loud ENOUGH then upgrade son!! lolI agree. I would think that with quite a bit more power (more then 2000) the btl would shine but doubt you would be unhappy with 2 sa 12's.
December 9, 201113 yr So you already have 1 sa-12 but you ordered a second and now asking which will be louder on 1500w? Well the answer is easy then, keep what you got and if it isn't loud ENOUGH then upgrade son!! lolI would think that with quite a bit more power (more then 2000) the btl would shinei disagree .. 2000 watts is just fine for a BTL
December 9, 201113 yr So you already have 1 sa-12 but you ordered a second and now asking which will be louder on 1500w? Well the answer is easy then, keep what you got and if it isn't loud ENOUGH then upgrade son!! lolI would think that with quite a bit more power (more then 2000) the btl would shinei disagree .. 2000 watts is just fine for a BTLx2What makes you think a BTL needs more than 2000 watts to "Shine" (whatever that means)? I hope not youtube videos.
December 14, 201113 yr Well since you already have 2 SA-12. Build a properly aligned enclosure and see what it does on the meter. To many variables to tell you which will be louder!
December 17, 201113 yr So you already have 1 sa-12 but you ordered a second and now asking which will be louder on 1500w? Well the answer is easy then, keep what you got and if it isn't loud ENOUGH then upgrade son!! lolI would think that with quite a bit more power (more then 2000) the btl would shinei disagree .. 2000 watts is just fine for a BTLx2What makes you think a BTL needs more than 2000 watts to "Shine" (whatever that means)? I hope not youtube videos.I was just thinking about previous setups I've had where subs like the dd9500's really come alive above a certain amount of power. I've only seen one btl in person on a rockford 1000bd and it moved a lot but also this kid tends to overdrive it. (way into clipping) so maybe they arent as power hungry as i am assuming???I've had a few 3000-4000 watt systems a few years back (10 years ago - single sub setups) but things were a bit different back then and I don't have enough personal experience with FI subwoofers to be taken too seriously. I've only heard a ssd and a btl (both 12's). Edited December 17, 201113 yr by IceWaLL
January 5, 201213 yr No sub comes alive at a certain point. Every sub made gets progressively worse in performance as power increases over 1 watt.
January 7, 201213 yr No sub comes alive at a certain point. Every sub made gets progressively worse in performance as power increases over 1 watt.Lol @ the raw truth
