Posted February 11, 200620 yr At long last, the RL-i8 is slowly but surely making its way through production Big performance in a "little" package, with the improved features we had been hoping for. Among the key differences to note:Improved Suspension for Greater Overall EfficiencyNew Basket featuring slightly Smaller Mounting Depth RequirementLower Moving Mass & Lower InductanceLower Fs, Lower Qts, & slightly Higher XmaxThiele-Small Parameters:Dual 4 OhmQts = 0.280Qes = 0.316Qms = 2.515Fs = 28.967 HzRe = 7.4 Ohms DCRLs = 2.961 mHVas = 21.98 LMms = 77.97 gCms = 387.1u m/NBl = 18.24 T*mSd = 0.0201 m^2Xmax = 18.3 mmSensitivity = 84.11 dB @ 1WSingle 4 OhmQts - 0.217Qes - 0.235Qms - 2.798Fs - 25.758 HzRe - 3.78 OhmsLs - 2.022 mHVas - 23.44 LMms - 92.47gCms - 412.8u m/NBl - 15.51 T*mSd - 0.0201 m^2Sensitivity - 84.14 dB @ 1WThese drivers are currently on sale and will perform optimally in the following enclosures:Sealed: 0.2 - 0.7 cu ftVented: 0.25 cu ft @ 35 Hz (Quasi butterworth) // 0.4 - 0.65 cu ft @ 23 - 29 Hz (EBS)Recommended Power: 200 - 400 wattsIn short, these b Edited February 24, 200620 yr by SoundSplinter
February 11, 200620 yr That's one sexy driver.The thing that really jumps out at me is the ultra small box requirements ... now that's attractive.
February 12, 200620 yr Looks like my e8a from behind with a black basket.Is there any clearance issues with the cone touching the basket on the downward stroke ?If my e8a had that much throw i think it would hit. Maybe uts because of the flat cone though
February 12, 200620 yr lol i just found this forum this morning and read from alllllll the way back. want 4 badass 8's sealed. kinda funny i just checked in now and he is ready to release them so really i dint have to wait at all does that make any sence?
February 12, 200620 yr they look great Mike, would there be a noticeable improvement over the older models?
February 12, 200620 yr Neeed......to......find......more.......space......under.....the.......rear.....seat!
February 12, 200620 yr Author > Is there any clearance issues with the cone touching the basket Not through its linear throw to be sure. I will be pumpin' some seriously excessive power to the driver this week and will see if this issue comes up, but it looks to offer acceptable clearance so I'm not expecting any problem.> Also, magnet boot's suckNot hard to take it off. > recommended rms power?350 wrms> would there be a noticeable improvement over the older models?This driver is 3dB more efficient than the older model and also features a copper shorting sleeve which will be sure to improve the sound quality. Enclosure characteristics will be comparable.
February 12, 200620 yr Admin WOW, finally they are on their way, will there be a mounting gasket?this could be the best 8"er out today
February 12, 200620 yr Looks great Mike!I may very well pick up a pair (or 4, or 6) at somepoint in the future.I presume high frequency extension is still rather limited on these?
February 12, 200620 yr > would there be a noticeable improvement over the older models?This driver is 3dB more efficient than the older model and also features a copper shorting sleeve which will be sure to improve the sound quality. Enclosure characteristics will be comparable.damn, you may just be receiving an order for another pair in a few months
February 12, 200620 yr > Is there any clearance issues with the cone touching the basket Not through its linear throw to be sure. I will be pumpin' some seriously excessive power to the driver this week and will see if this issue comes up, but it looks to offer acceptable clearance so I'm not expecting any problem.> Also, magnet boot's suckNot hard to take it off. > recommended rms power?350 wrms> would there be a noticeable improvement over the older models?This driver is 3dB more efficient than the older model and also features a copper shorting sleeve which will be sure to improve the sound quality. Enclosure characteristics will be comparable.<{POST_SNAPBACK}>I would like to know the results. Excessive power....uughhh ughh uugghh / tim allen gruntThose baskets arent really that deep for how much throw the woofer has.
February 13, 200620 yr I presume high frequency extension is still rather limited on these?<{POST_SNAPBACK}>c'mon dude? they're subs! you want mids? buy something else
February 13, 200620 yr im curious mike what the difference in performance will be between these new 8s and the proto 8s i have on my shelf? i havent done anything with them yet as the rl-p 12 sounds so good i.b i havent botherd to buy any mdf? i only modd when im not satisfied.
February 13, 200620 yr does kinda look like a TC9 motor,3" VC?, looks bad ass... Keep up the good work guys.
